Results 1 to 7 of 7
    Established Member Two Rings DJT's Avatar
    Apr 23 2016
    Question Help on Deciding: Differential Inserts
    I already bought the 034 MOTORSPORT TRANSMISSION MOUNT INSERT for my 2013 S5 Cabriolet.
    I wanted to add the Differential Inserts and see there are a few different options:
    1- 034Motorsport Billet Aluminum Rear Differential Mount Insert Pair (Front)
    2- 034Motorsport Billet Aluminum Rear Differential Carrier Mount Insert Pair (Rear)
    3- APIKOL REAR DIFFERENTIAL MOUNT INSERT KIT
    4- ECS Tuning: Complete Rear Differential Mount Insert Kit
    Any suggestions/pros/cons on choosing between the options above as I will do front and rear? The ECS kit is polyurethane and 034 is aluminum so any thoughts very much appreciated!
    TIA,
    -DJ
    2019 S5 Cabriolet | Prestige | Quantum Grey Metallic
    TRADED: 2013 S5 Cabriolet | Prestige | Misano Red
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Choose the polyurethane bush inserts if they are available, they are more forgiving, introduce less vibration but are still a definite upgrade from standard.
    Oct 09 2008
    Eurocode also has some inserts as well to add to your indecisiveness
    The Awesome™
    Mar 05 2014
    SF Bay Area
    aren't they pretty much all the same? I mean the shape is dictated by the the mount. I'd go with the cheapest one.
    Established Member Two Rings TTALMS's Avatar
    Jul 02 2009
    2011 Range Rover
    Dallas, TX
    I have the entire 034 package: (1) rear differential carrier mount inserts; (2) transmission mount insert; (3) rear differential mount inserts; and (4) street density transmission mount. They work very well together. Very little vibration, if any at all.
    JHM linkage w/ USP SS line : test pipes : pulley : intake spacers : tune : 2-pc rotors Ecode shifter : sways : end links : AK : Sport UCAs w/H&R coils & CR-15 AWE Non-res downpipes w/ GMG exhaust : intake tube w/ APR CF intake 034 mounts & inserts Style VFF103s : DEVAL : BFI knob/boot : custom s-wheel : CF inlays
    Apr 23 2016
    Thanks all for the responses. I'm going to call ECS and likely just order their new inserts today.
    Cheers,
    -DJ
    Veteran Member Three Rings ColtS5's Avatar
    Aug 18 2013
    2022 Kia Telluride, 2024 Jeep Grand Cherokee, 2018 Porsche Cayman S
    Indianapolis
    I also purchased the ECS kit.
    It was much firmer, nice, but it did introduce some vibration, especially with city driving. I ended up removing the lower diff mount, the aluminum two piece, and just used the rear mounts, and I like it much better. Give it a go, and if you find the same, remove the lower mount first.
    Good luck!
