Results 1 to 13 of 13
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    Metal impeller vs OEM
    Has anyone had the non OEM metal impeller fail ? I have heard two instances of the impeller breaking off and gouging the block. Right now I am debating between the OEM one and the metal . Any feedback would be valued .
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    I have never seen broken OEM water pump. I have heard that 1.8t's have had this problem.
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    I've been running the HEPU metal impeller going on 2.5 years now.
    The plastic impeller on my car before that actually seperated from the shaft. So the pulley would spin, but the impeller wouldn't turn with it.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    I never had an issue with an OEM Audi WP (plastic) on a 2.7T, but if I were going aftermarket I wouldn't go plastic.
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    I upgraded my water pump impeller with one of these
    Nov 06 2007
    B5 S4
    Houston
    Maybe I am overthinking it , also I have been told the metal impeller has more pieces ,ergo greater likliehood of failure . At this point I am now 50/50.
    Dec 07 2004
    Finland
    The metallic impellers what I have seen, look inefficient to me. Like this:
    Compared to this:
    May 25 2014
    Long Beach, CA
    https://www.europaparts.com/water-pump-078121006a.html
    HEPU uses the OEM impeller design.
    I would recommend you use an OEM gasket though.
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    I was running a metal propeller pump, not sure of the brand. It lasted only 30k before the bearing started to make noise. Thankfully I picked up on it quickly and acted before it had a chance to fail completely. My shop replaced it with an OEM one which has the plastic propeller. At first I was disappointed as I always thought metal was an improvement over OEM. But after doing some research I am sure it will be fine as long as you replace it as recommended, IE every 60k. If you leave it in there well past the recommend interval I am sure the plastic is at risk for breaking down. Also in some of my searches I found people stating that the metal pumps are more prone to bearing failure.
    Looking for a good shop north of Boston, call Eurosport Performance
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    My factory pump bearings seized up causing the timing belt to fail and damaging the engine at 30k back in 2002. I've also had an aftermarket pump quit around 30k but fixed it before failing. Current aftermarket pump is good at 40k.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    I've had the propeller fall off on a OEM (plastic) water pump.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Nov 06 2007
    B5 S4
    Houston
    Quote Originally Posted by okkim View Post
    Compared to this:
    That looks like a pretty big difference.
    Aug 06 2008
    Canadia
    Sounds like a crap shoot, FWIW i have a metal hepu or whatever wacko name it is been fine so far (40,00km or so) before that i had a cheap aftermarket one with plastic impeller and it leaked
    the B5 S4 is like the mafia... there is only one way out!
