Results 1 to 29 of 29
    Apr 15 2014
    Ottawa/Gatineau Canada
    Can B7 X2 intercoolers for the 2.0 be fit to a B6 1.8t?
    Wondering if they can be fitted.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Junior Member Two Rings
    Apr 12 2016
    Ontario/Canada
    x2 I just got myself a set of these as well.
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Yes. You need the mounts, intercoolers, hoses and ducting. It's all bolt on.
    Apr 15 2014
    Quote Originally Posted by hooligander View Post
    Sure hope you did not get them from a part out in Quebec.
    Veteran Member Four Rings FNK's Avatar
    Mar 07 2010
    Sherbrooke, Qc
    Why not from a part out in Qc?
    Apr 15 2014
    Quote Originally Posted by FNK View Post
    Thats where I want to score mine mon ami ;)
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Because someone perhaps got there first would be my guess.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Apr 12 2016
    Ontario/Canada
    No Ive had them for a few weeks now. I know there is a thread on this, I believe they are called DSMIC (Dual Side Mount...)
    I have the cores and misc hoses not sure about the mounts
    Apr 15 2014
    Who here has actually done this?
    Notice any significant IAT changes??
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Previous owner of my B6 1.8T installed DSMIC to combat IATs with the APR Stage 3+ kit. Still waiting on maintenance/work records from him, so not sure if he went the B7 DSMIC route. He preferred this option instead of a FMIC for cosmetic & California SMOG testing reasons.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Jan 31 2015
    Boise Id
    I installed a passenger side B5 S4 SMIC in my car not too long ago but haven't done any logging with it. The main difference I noticed is that my temp related pinging has cleared up significantly.
    Jul 17 2013
    Utah
    I have done a B7 passenger side intercooler swap. Some things to keep in mind. You will need to relocate or delete your seconday air pump as it will not fit in the stock location. The turbo outlet hose on the B6 can be rotated 90 degrees to supply the new intercooler, but you will need to fab up an outlet hose to the crossover pipe hose or you will need to swap over the B7 crossover pipe and then you can use the B7 intercooler outlet hose. I ran this set up for about 6 months on a frankenturbo before I blew apart the passenger side intercooler. I ended up tearing it out and fitting a treadstone TR6 intercooler with china intercooler pipes. The cost was just slightly more than the b7 setup and only a bit more work to fit, but the performance is significantly better than the stock dsmic setup
    Apr 12 2016
    Ontario/Canada
    Quote Originally Posted by ryanj View Post
    Did you guys use the guide on AZ?
    Apr 15 2014
    Im kinda on the fence if this mod is going to be worth the time and $$ for the gains VS just getting a better SMIC
    Senior Member Two Rings WeekendDriver's Avatar
    Oct 03 2015
    Audi A4 B6 1.8T (BFB), 1972 Fiat 124
    Quote Originally Posted by Luxus Panzer View Post
    A better single SMIC won't be bolt-on, will it? Besides, how much bigger a radiator can you stuff in there?
    Jan 03 2008
    Richmond
    I would call it more bolt on than DSMIC. As I understand, the Tyrolsport SMIC just pops into where the stock one is and uses the same pipes. Either way, the bumper is going to have to come off and from what I've read, the radiator support has to move forward a bit to get the old intercooler out. I would expect it would have to move out to get a second intercooler into the other side.
    Oct 03 2015
    I see. Apparently, you can actually put a larger radiator there.
    That price, though...
    Jan 03 2008
    Richmond
    Yeah, the price is nothing to shrug at. Apikol makes a cheaper one at ~$450
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Apikol is considerable smaller than the Tryolsport SMIC. The Tyrolsport has nearly the same volume as the smaller FMIC available (E-Code, ER sport, etc.). Both kits both on without much hassle.
    With a dual SMIC the additional piping and bends play a factory in overall response compared to an upgraded SMIC. In terms of heatsoak a FMIC will be better compared to a SMIC, however a quality SMIC would likely outperform a cheap-o FMIC.
    2019 SQ5 Prestige
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    Unless you're stuck on the SMIC/DSMIC, why not go with a Treadstone FMIC core? I picked my TR6 up for $250 and then used some piping I got off Aliexpress for under $85 bucks. My IATs never rise above ambient more than 10-13 degrees under load.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Oct 03 2015
    That Aliexpress link redirects to the landing page, can you please fix it? I'm very excited about a drop-in piping kit :)
    The only reason not go for FMIC that I know is when you don't have a S4 front bumper and you don't want to cut the reinforcement bar of your stock bumper either. Because cutting is required to fit most popular coolers like the one from B8 A4.
    Having said that, it is possible to stick a reasonably sized FMIC without cutting the bumper, but the search for actual mass-produced cooler of suitable size still continues, AFAIK.
    Fry Sauce, UT
    Quote Originally Posted by WeekendDriver View Post
    Strange, the link works on my end. Just search Aliexpress for "New Intercooler Piping Kit fit A4 1.8T Turbo B6 Quattro 2002-2006 black". Current price is $46.46 w/$34.33 shipping so $80.79 total.
    I didn't have to cut the reinforcement bar with my TR6. Just had to do some trimming behind the bumper. However, I have a USP so I don't know how it'd compare to a regular one.
    - Steve
    NKAWTG
    Oct 03 2015
    What's USP?
    Apr 01 2007
    houston texas
    Depending on the size of your core, you shouldn’t have to trim the bumper valance or rebar(crash bar).
    For the core to fit between the bumper valance, AC condenser, and rebar without trimming it will need to be 2.25” or thinner. To retain your fog light grilles the length from end tank to end tank will need to be no more than 28”.
    My EuroCode Tuning FMIC fit with ZERO trimming, and sits behind the rebar. Its 2.25” thick, 10” tall, and the core itself is 18” wide (405cu).
    2019 SQ5 Prestige
    Oct 03 2015
    Thanks for the dimensions!
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    What's USP?
    Its the abbreviation for "Ultrasport". He's saying he has an Ultrasport, whose bumper may provide more clearance for piping than a regular A4 bumper.
    Oct 03 2015
    Ah! I think it's called the "S-line" bumper around these parts. If so, then indeed it does provide more clearance. For instance, no cutting is required to fit the B8 FMIC.
    Jan 03 2008
    Richmond
    My FMIC is 27.5 from inlet to outlet, 6.5 tall and 2.5 thick. I had to trim the little hooks at the bottom of the bumper, but the core sits happily below the rebar. I still have fogs with covers.
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Quote Originally Posted by texasboy21 View Post
    Apikol makes a larger SMIC that's pretty close to the size of the Tyrolsport. I'm currently running one.
    http://www.ringer-racing.com/product.sc?productId=295
    2005 A4 USP (Gone)
    2012 S4
