Results 1 to 13 of 13
    Senior Member Two Rings The Overclocker's Avatar
    Mar 17 2015
    Montreal
    Power window relay ?
    Can't figure out what relay is related to the power windows
    Mar 17 2015
    Montreal
    Any tip guys ?!
    Nov 03 2011
    All Over!
    It's a double-size relay, designated 365.
    1986 Type 85 Audi 90 quattro
    Nov 03 2011
    All Over!
    What year is your B5?
    Mar 17 2015
    Montreal
    Its a 2001 american car
    Mar 17 2015
    Montreal
    I dont have the relay 365
    Mar 17 2015
    Montreal
    Any idea ?
    Aug 09 2013
    1985 Mercedes 380SL (Brünnhilde), 2001 A4Q 2.8 5spd (Frau Blücher)
    Havre de Grace, Maryland
    If you're trying to find this relay because your windows aren't working try checking the comfort control module behind the passenger side trunk panel. My windows/sunroof, locks, and interior lights were all messing up/not working and as soon as I replaced the CCM everything went back to normal. When I looked at the old module, the connections were corroded because it got wet somehow.
    Mar 17 2015
    Montreal
    Quote Originally Posted by Stashman94 View Post
    Thank you very much for this info
    Did you have a relay as well or only the ccm module in you're audi ?
    So that if i check the ccm module & its not that i can route the relay's location & trouble shoot it
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    honestly I would check to wires in the driver door, i have 2 separate a4's Both of them had a power loss due to the wires breaking in the doors, Ran a new wire through and hooked it straight into the driver window switch Entire system came back, including the top window, i seen this post while doing my own repairs, so i know that there is probably a wire that has broke in the door "Happens all the damn time." all u have to do is run a wire from a relay to the door switch and push it into the Red slot only Browns are grounds, after u plug it in, Its as simple as pressing the button If it works then u know u need to re run the power. thats about it
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
    Mar 17 2015
    Montreal
    Quote Originally Posted by Radskull1 View Post
    I still cannot figure out witch relay it is !!
    I posted pictures of all the relays but cannot know witch one it is or is it even there ..
    Sep 13 2014
    somewhere
    my cars re a 99 and 00 Prefacelift and post, Neither have a relay for the windows just fuses
    Mar 17 2015
    Montreal
    Guys big update
    I replaced the pump in the trunk with a little bit of the harness because it was damaged
    Windows & door locks now works !!
    But when i press lock or unlock on the key nothing happens ...
    Any tips for me to get this working ??
    That was the problem
