Results 1 to 10 of 10
    Senior Member Two Rings MkUrMark's Avatar
    Aug 09 2015
    Southern Cali
    Anyone else notice different gear changes at different temps?
    I notice an odd behavior when temperatures spiked in to triple digits this last few days ago... it may not have to do with the heat but thats my only connection I can correlate this with.
    Usual driving patterns while on D, gears shift up between 1800-2000 rpm range. I notice during the really high temps 102º+ gears shifted up between 2200-2800 rpm range with no change in throttle input. As temps went down through the day (<100º) gears changes returned back to the normal pattern.
    I had no codes or anything else, I was thinking it may have something to do with turbos working harder because of the heat soak but not sure if that would make sense.
    This is my first automatic transmission in years not sure if this is normal behavior in general with automatics. I wouldn't think its worthy of dealer visit, car operated normal other then that.
    2016 S3
    12' Golf R:. Stg 1+sold
    10' Gti sold
    06 A4 sold
    Aug 06 2012
    san diego
    normal. when temps get high the car wants to keep the revs higher. it does this to keep the engine fan moving faster which helps regulate temps better
    Aug 09 2015
    Southern Cali
    figured thanks man
    2016 S3
    10' Gti sold
    06 A4 sold
    Established Member Two Rings eXhilarat3d's Avatar
    Mar 31 2011
    Las Vegas
    It's hitting ~110 deg in Vegas and my car will hold a gear to 3k. I thought there was something different going on since there was a lot more sound coming from the engine and exhaust lately. My car is exhibiting the same behavior. Car is completely stock except for springs and wheels spacers.
    '19 E-Tron Prestige
    Wife: '22 Q5e Prestige
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Quote Originally Posted by markn1689 View Post
    Lol. Belt-driven fan in a transverse engine bay?
    "You know you have a bad idea when Ford guys are making fun of you."
    Mar 22 2016
    Las Vegas, NV
    Quote Originally Posted by eXhilarat3d View Post
    Hi! Did you flash your lights to me Thursday evening when you were turning into the Chevron on Windmill/215?
    Apr 11 2012
    I read somewhere it's trying to make the same requested amount of power and it needs to rev higher when it's hot outside to do so.
    Aug 09 2015
    Southern Cali
    @ chris164935- haha true that...
    2016 S3
    10' Gti sold
    06 A4 sold
    Mar 31 2011
    Las Vegas
    Quote Originally Posted by Lusky View Post
    No, that wasn't me. I'm rarely out that way....
    '19 E-Tron Prestige
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by chris164935 View Post
    i giggled at that response as well
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
