Something went wrong for it have been able to boost to 30psi. Since you don't have a tune, I'd put it back to stock as much as possible.
If you don't have a tune, then it's NOT supposed to go to 17psi.
What manual boost controller do you have? If you're still running the n75 and the MBC, the n75 is probably trying to keep you in limp mode (5psi of boost) while the MBC is screwing with things.
It sounds to me like you're trying to push more boost than a stock tune is supposed to, and then are reading different complaints about the brand of turbo you have and confusing yourself about the whole situation.
If you think it's a bad actuator, take the turbo off and make sure the preload is set correctly... Raise the top nut up a few threads, raise the lower nut up against the wastegate arm until finger tight. Mark the nut and the wastegate arm piece, now with a 10mm wrench, tighten the lower nut three turns. Some
Might say do it more, but that's the right way to do it. Make sure you lower the top nut down onto the wastegate arm piece. Also make sure you put the retaining clip back on.
If you think the wastegate actuator is bad, attach a source of controllable compressed air to the wastegate line. Start at 0psi and very slowly increase the psi of air. This will identify the crack pressure of your wastegate. It should be between 6-8psi.
If you think the wastegate arm may be faulty, see if you can move the wastegate arm in and out from the turbine housing. This would be a failure of the wastegate bushing.
If all that checks out then your wastegate is fine. Next step would be to consider how you have the MBC plumbed. If it is in parallel with the n75(to prevent spikes) your MBC may be sticking and the n75 is catching hell bc of it, if the MBC is inline with the n75, I'd definitely suspect a faulty MBC.
If you don't have a tune though, you're pushing it to operate WAY outside the normal range of boost. You're right, a ko4 can be used with no problem with a stock tune. However, this isn't the case here. It's still not necessarily catastrophic, but the ecu is definitely going to be fighting you on the boost your trying to make.
Last thing, if you have vagcom, check your codes, clear them... If be willing to bet that for the next few minutes the car would run like you expect it to... After that, back to what it's doing now.
