Results 1 to 25 of 25
    May 14 2015
    993; 550 SL, Mini S
    Oregon
    S4 is tram lining, help sought
    2015 S4 is Tramlining on original Contis. Alignment is from the factory.
    It's not horrible, but more than I expected. I'd hoped it would get better with some tire wear, but at 7k it hasn't.
    Suggestions?
    Mar 05 2014
    2020 SQ5
    PDX
    It doesn't really. The contis are horrible from about 7k on to when they die at 15k.
    Best things you can do is just maintain a high PSI, something like 40F, 37-38R
    Veteran Member Four Rings BirdmanQ5's Avatar
    May 31 2012
    2017 Audi S3
    Toronto, ON
    Get new tires ASAP. Contis are so bad.
    2017 AUDI S3 | TECHNIK | DAYTONA GREY | BLACK OPTICS | SUPER SPORT SEATS | ADVANCED HANDLING | TECHNOLOGY PACKAGE | AWE SWITCHPATH 102MM | ED SPOILER | 034 SPRINGS + REAR SWAY | VORSTEINER VFF102 20x9 ET35 CARBON GRAPHITE | THINKWARE F770
    2016 AUDI S3, 2013 AUDI S4, 2011 AUDI Q5, 2010 AUDI A4, 2006 AUDI A4
    @IALEXSERBERT | @AUDI_TN | @SIXAUTO
    AUDITRUENORTH//
    WWW.SIXAUTOCONCIERGE.COM
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    6,500 miles on my Contis and they are completely bald...they are absolutey horrible tires. Upgrade to something like PSS...that's what I'm doing.
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Noticed i need tires soon at 9000 (stock Continentals) miles pushed then to slicks to 13180. Upgraded to Michelin Pilot Super Sports as the forum suggested on Friday. Initial impressions are stickier and way quieter.
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Feb 06 2015
    I'm at 9k on the contis mines are starting to get noisey. I have plenty of thread on mines tho refuse to swap since I might be parting ways with the S4 come December.
    19’ Audi RS5 SB H&R VTF Has Kit|034 Motorsport|ECS Tuning
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Get an 034 x brace or alu kreuz, but yea those tires suck too!
    Sent from my SM-G925V using Audizine mobile app
    Aug 06 2015
    MA
    +1 to PSS = tramline cure. Had it myself on contis at 40k
    May 06 2004
    W124s
    PA
    Yep, I have the Continentals. Same issues here. Even with frequent alignment checks they wear poorly and get noisy.... Follow every rut and dip in the road. Quite annoying
    Keep right pass left, it's the law!!
    Established Member Two Rings TheLetterJay's Avatar
    Sep 26 2015
    ATL | NYC
    Stock tires suck! It sounded like I had a bad wheel bearing whenever I made turns.
    Better tires and a stabilizer brace will cure this issue.
    From my Moto X Pure using Tapatalk
    2018
    034 Mounts, Inserts, Rear Sway, Front Strut Brace | ECS Intake, FMIC | ABT H.A.S. | Forgestar
    Gone
    2014 S-Tronic
    Eurocode Alu Kreuz | CR-15 | 034Motorsport Transmission Mount, Strut Mounts, Rear Subframe Inserts | Solo-Werks | ECS Luft-Technik Intake, Rear Diff Mount Inserts
    Deactivated Four Rings
    Sep 15 2008
    Is Big
    Fort Worth, Texas
    I just swapped out my Conti's two weeks ago for some Hankooks Ventus...world of difference. Rides so much better and a whole lot quieter.
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    My Contis tramlined bad, especially at the end of their tread life. Switched to PSS two months ago, problem completely solved.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Jul 07 2015
    Salmon Arm, B.C. Canada
    I switched to some new Pilot Super Sports when I put the OEM tires/wheels back on and they were louder than my winters! They really aren't great tires, but you may me able to get a few more miles out of them by rotating them. I know my dealer said that you don't rotate tires on AWD cars, but when I told that to the guy at the tire shop that, his comment was that they should stick to selling cars. I will be rotating my new ones every 8000km for sure!
    2014 Estoril Blue S4 Teknik, Sport Diff
    2005 BMW R1200GS
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by S4inBC View Post
    Weird, mine are super quiet. They ride great and transformed the on-center feel dramatically.
    Jul 07 2015
    To clarify my statement. I love the new tires. Going from my winter setup to the stock Conti's was a shocking increase in noise! The new Michelins are indeed quite amazing, I can't imagine why better tires aren't selected for this car out of the factory. My tire guy was pretty emphatic that they should be rotated regularly though.
    2005 BMW R1200GS
    Veteran Member Four Rings SilveR316's Avatar
    Jun 02 2013
    Downtown Toronto
    Yet another confirmation that the stock contis suck.
    I had horrible tramlining with stock contis. I switched to Michelin PSS and it went away completely.
    2017 S6|Sepang Blue|Black Optics|Silver Mirrors|ASC WiFi Module|AWE Exhaust|034 Drivetrain Mounts
    2014 S4|Prestige|Estoril Blue|6MT - AWE 102mm|Alu Kreuz|KW H.A.S.|SPC Control Arms|20x9.5 Vorsteiner V-FF 102|Vorsteiner Front Spoiler|Deval Valence - Build - SOLD
    Aug 26 2012
    2013 S4 Ibis 6MT
    Okay, now I follow, thanks for clarifying. Rotation seems like a good idea as well although I usually just keep an eye on the treadware to see if there is any unevenness.
    May 14 2015
    993; 550 SL, Mini S
    Oregon
    Thank you gentlemen. I'll look to replace the Conti's first, then consider a brace if the problem doesn't go away.
    Apr 10 2016
    Reading/PA
    I've also noticed this car tramlines worse than my previous cars... Just curious, does anyone know what causes a car to tramline worse than others? It did it with the winters that were on when I bought the car, and still does it with the new summers I had installed.. It seems to have gotten worse after putting spacers all around, too, or is that my imagination? Is it soley a chassis rigidity issue?
    Aug 06 2015
    MA
    Quote Originally Posted by dls11b8 View Post
    Have you had an alignment recently? What tire pressure are you running at front and back? Tire size?
    Veteran Member Four Rings Race Shooter's Avatar
    Dec 22 2006
    Raleigh
    Dont expect the all powerful PSS to solve your issue though. This car does tramline pretty badly, as do most cars with low profile and wide tires. Tires may help, but dont count on it being a night and day difference.
    2014 Porsche Cayman S Guards Red
    2015 Sepang Blue S4 6MT Gone...easily forgotten.
    2004 Nogaro Blue S4 Avant 6MT Gone...but severly missed .
    Jim Sykes Photography motorsports photography
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by Race Shooter View Post
    In my case, the difference was profound but I'll be curious to see if the tramlining returns more as the tread wears down.
    Apr 10 2016
    Reading/PA
    Quote Originally Posted by mungie View Post
    1) No, they checked it when I had the tires installed, and they said it was 'in factory spec', but didn't give me numbers. I can see there is a bit of neg camber on all 4, the car tracks straight on most road surfaces that aren't rutted or overly crowned.
    2) 38f/38r
    3) 245/40-18 (Stock wheels)
    edit - I'm pretty certain the previous owner had suspension & wheels on the car, as the springs and struts look brand new compared to the rest of the suspension components and the fenders are rolled, but the dealer vehemently denies it... Not sure if they may have tweaked something at some point..
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Last Friday I had a set of PSS's put on and an alignment done at the dealer. The car feels 10x better!
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    May 14 2015
    993; 550 SL, Mini S
    Oregon
    Necro'ing the original thread as I forgot to update it.
    I switched to the PSS from the Conti, problem solved.
