Results 1 to 19 of 19
    Active Member Two Rings audialucks5's Avatar
    May 26 2016
    1973 mach one, 351 cleveland
    Ohio
    Can anyone tell me what this Y tube is for?
    Established Member Two Rings audis4noob's Avatar
    Nov 21 2015
    oregon
    spider hose.
    Sent from my Z936L using Tapatalk
    Nov 21 2015
    oregon
    Breather hose iirc they go to your egr valves
    Jun 08 2014
    Vancouver, Washington
    Clean the bay omg. If its not a parts car
    Feb 27 2011
    Winnipeg
    goes to each combi valve, its attached to the SAI pump to the right underneath the brake booster vac line
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    I think this is the dirtiest engine bay I have ever seen 😳
    Jan 12 2009
    Quote Originally Posted by mikeb17 View Post
    lol
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Quote Originally Posted by audis4noob View Post
    2.7 motors don't have Exhaust Gas Recirculation system. That hose hoes to the SAI combi valves as already said.
    Nov 21 2015
    oregon
    O ok thanks for correcting me
    Veteran Member Three Rings 01nogaro's Avatar
    Nov 05 2010
    B5 stuff
    Portland OR
    simple green
    01 Nogaro Stage III - Sold
    01 Laser Avant - Current
    May 26 2016
    Ohio
    It's a project car. Just purchased it and haven't done any work to it. The bay is very dirty I know lol. I don't have the money to buy parts needed to get it road worthy yet so until I do it's gonna stay greasy
    May 26 2016
    Ohio
    Where can I find the hoses to connect this to the valve?
    Aug 06 2008
    Canadia
    Quote Originally Posted by audialucks5 View Post
    Should be easy, most people code out SAI and remove the parts, just post up a WTB ad im sure someone has them sitting in their garage in a box.
    the B5 S4 is like the mafia... there is only one way out!
    May 26 2016
    Ohio
    Quote Originally Posted by MacDaddy View Post
    Whaaaat? New to the forum and the S4, gonna need some simpler terms
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    You have a tip? It's secondary air as other have said. Check out my thread to see my fix:
    http://www.audizine.com/forum/showth...-My-1-000-2-7t
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Because you're not on the east coast. I've seen worse.
    May 26 2016
    Ohio
    Quote Originally Posted by wbrunner23 View Post
    Where does the secondary air attach to?
    Established Member Two Rings siffer's Avatar
    Dec 26 2006
    Huh
    Just set it on fire already. Put it out of its misery.
    May 26 2016
    Ohio
    Quote Originally Posted by siffer View Post
    ? Every car has potential, just gotta put the work in.
