Results 1 to 11 of 11
    Feb 15 2016
    Cambridge,Ontario
    DV valve noob question
    As this is my first turbo and fairly recently purchased, how would I know if i have a bad dv. " down on power " is relative and does not help a new owner. Will a leaking DV throw a code ? ( I have an 06 ) was going to climb under and see if it has been upgraded at some point.
    Thanks
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Thanks
    It would throw an under boost code I believe.
    But taking a quick is the best way.
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Feb 24 2004
    Minneapolis
    I just had a P2261 - 008 - Mechanical Malfunction - Intermittent. As others have seen, I had some power drops/surges - only perceptible if you pay a lot of attention to your car. A new piston DV seems to have solve it. Did it 3 days ago, haven't had a code since.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jul 14 2015
    Sydney
    If you are upgrading your DV. Go the DV+ route. It's honestly one of the best bang for back upgrades both from a performance and reliability perspective.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by shahk62 View Post
    I see people say that but I haven't seen any data to back it up. Is there data or is it just just butt dyno?
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Quote Originally Posted by mtroxel View Post
    You're never going to gain power with a DV+. You'll also never have the same issues with a torn DV again. I installed mine a few months ago on my JHM Stage 2 tuned car and I notice better off throttle, on throttle response. Like I said, it's not a power adder, but it is a great investment.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jul 14 2015
    Sydney
    It's not something that can show up on a dyno. But especially if you have a 6MT transmission you'll feel sharper boost responses after shifts
    Senior Member Two Rings UberTeile's Avatar
    Sep 01 2010
    Southeastern, PA
    I think DV+ owners interpret having "power sooner" as "more power", which isn't completely inaccurate. An increase in response is basically an expansion of the power band. Even without an actual 'power increase' that is technically having "more power" because that power(albeit "stock") exists at an earlier point than before the DV modification.
    ll Audi Sport "Vorsprung Durch Technik"
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by UberTeile View Post
    I think DV+ owners interpret having "power sooner" as "more power", which isn't completely inaccurate. An increase in response is basically an expansion of the power band..
    I understand, we all know it's not going to make more power. I believe they are claiming less turbo lag. And if that's true, I wish there was proof.
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    The DV+ improved the OEM design DV to be essentially more failsafe and faster response to opening and closing. The diaphram design is very quick and "snappy" but failure probe to tearing the rubber diaphram with time (heat / oil) and thus vausing leaking under boost. The OEM piston design is very fail safe but slower to respond. It also does not seal 100% causing a smooth torque curve on boost due to this slower response and lack of 100% seal (but not enough leak to trigger an underboost code)). The DV+ maintains excellent seal and fast response without failure prone diaphram. It works with piston and pneumatic changes to snap shut on boost. There is a good video that GFB released on how it works, just search.
    Best way to check your DV is to just remove it and check. Installing the GFB DV+ is a nice upgrade to never have to worry again and maintain best performance. I have not heard of a failure yet and mine runs great, easy install.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    I didn't receive a CEL when my OEM DV failed. Likely would have never known if I wasn't tuned and I didn't have a boost guage because my blown DV would boost up to factory pressure, rather than the 22psi where it should have been after tune.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
