Results 1 to 32 of 32
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Dual Pulley (DA + 2872ft / 89F) results --> [email protected]
    Hi all,
    Just thought I'd share my results from tonights Street Heat event at Bradenton Motorsports. Showers in the area, which resulted in high humidity, low barometric pressures, and generally higher temperatures around 8pm. I only ran twice, as it eventually rained out within an hour and a half being there.
    The density altitude was 2872 feet in effective elevation, the national weather service says 89F, but my car temp gauge said 93F, and IIRC weather.com says 91F, so I'm not sure which one is 100% accurate based on my actual location. My mods are the same as before aside from finally upgrading my S/C cooling system:
    GIAC stage II RACE file
    GIAC TCU
    AWE-tuning s/c pulley
    JHM O/D pulley
    Chipwerke Pro set to 3-1
    AWE coldfront w/ upgraded pump (I should have done this a lot sooner!)
    034Motorsports intake tube
    aFe filter
    2.5" drilled airbox
    exhaust x-pipe
    My fuel was 1/2 tank of my usual 93/e85 mix. Tire pressures were 39f/38r on Michelin PSS, spare/jack all intact in the car, so essentially no weight reduction. I did NOT utilize launch control, but used the "primetime" method. I also have a larger custom crank pulley on order waiting for its arrival and installation, hopefully I can reach my goal once FL weather sees high 50's/low 60's this fall before installing that larger custom crank pulley.
    Breakdown of my timeslip:
    reaction .151
    60ft 1.627
    330ft 4.749
    1/8mile 7.355
    mph 94.47
    1000ft 9.594
    1/4mile 11.490
    mph 118.98
    With my current set-up, it looks like I can run 10.9x-11.0x based on online calculators in "perfect" conditions. As such, I'm VERY VERY VERY happy with this time considering it was done in 2872 ft. density altitudes in temps between 89-93F (typical FL summer day, with high humidity). I'm also excited that I finally solved all of my WOT upshift issues, previously it would pause/hang for a split second on the 3-4 upshift with the Chipwerke set to 4-1 (up to .16 seconds recorded on logs on my 11.2xx second runs), I have dialed it down to 3-1 and now the hang-up hardly exists in logs.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Hell yes. You'll be in the 10's with a negative DA
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    For sure. 10's with a low da.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I love it, Loe. You're killing it.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Just came back from race warz to see this... Dayum Loe!
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Great work again Loe.
    Pushing the boundries nicely
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    First stock blower 10 second pass...looking forward to it this fall. Excellent work.
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Aug 09 2015
    Sarasota, FL
    Thanks guys! 4-5 more months until there will be some relief in weather, it can't come soon enough
    The car was definitely down on power compared to running in cooler weather, on my previous 11.4xx in 1,300-1,400ft. density altitudes pre-s/c cooling upgrades I would see 1/8mile traps at least 1.5mph higher, and I would gain 25.xx-26.xx mph in the last half of the 1/4mile resulting in a 119.xx mph (I only gained 24.51mph on the run in this thread).
    I also have larger pulley with my name on it, just waiting for it to be built (2-3 weeks). I may sell my JHM unit, but I may just keep it just to see if I can hit my goal with it, and then swap to see if there is a difference in times.
    Jun 17 2010
    Madison WI
    This is awesome, love seeing the progress you continue to make! Would enjoy seeing video next time :)
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Nov 28 2015
    Montreal, QC
    since you are really into timeslip and such.. i don't get why you haven't invest in LW rims + a proper intake, I'm sure this will cut .1 second ! ( maybe even .2 if you add cat-back + DP) as I suppose the more power you make, the more gain the exhaust produce) and a set of 200 treadwear tire would help you much too.. I ran the direzza Z2, sure they are more noisy than the pss, but they do grip more :) the z2 is, IMO, the more civil tire out of all the 200 treadwear tire.
    keep it up ! you are leading the rest to a 10sec car.
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Amazing numbers in those conditions.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Awesome run Loe, good to see the car running strong again!
    Sent from my Note 5
    Bryan
    Jul 21 2004
    South Florida
    Great job loe. Car is strong man. January it is.
    mike
    2018 Audi S5
    Gone-
    Jul 28 2009
    Philadelphia PA
    How much boost were you getting with that DA? It's 115 degrees here in phoenix now. I may get 15 psi in this heat giac stage 2.
    c8 a6 allroad
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    These results are encouraging, great times! So basically if I go GIAC Stage 2 + TCU + Cooling + larger crank pulley + E85 I'll be in the mid 11's, easy? Running the Chipwerke in addition seems "hackish" to me. I thought the GIAC files already requested more boost than the car could create, so they would automatically take advantage of extra boost if supplied. (from the larger crank pulley)
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by rtl5009 View Post
    I need a P3 boost gauge soon, I would venture to say based on my 1/4mile times that it's more than likely "only" 16-17psi that I saw last night given the barometric pressures.
    Quote Originally Posted by Acejam View Post
    The Chipwerke Pro box is needed to get a its full potential, however it's not required to run one. Without the box, the GIAC will bleed at 10-20% up to 5,200-5,300rpm, will shut completely directly after, and slowly start bleeding up to 5% after 6,800rpm as the boost exceeds requested on a GIAC stage II. With the Chipwerke set to its mild setting, I get .08-1.xx% around 4,800-5,000rpm, but it remains at 0% after that.
    Prior to adding a Chipwerke (and also a cooling system upgrade), I was only able to run an [email protected] in 1,470ft. D/A's. After I added just the Chipwerke, I ran a [email protected] in 1,337 ft D/A and a [email protected] in 1,298 D/A. The D/A's are very close to each other to be considered negligible, however its a good point of reference, though it's not an exact science as different track days will result in slightly different times based on prep ect ect...
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by waxxonMTL View Post
    There is a possibility of LW rims/better tires and a true intake helping. However I'm not sure how much LW rims or 200 treadwear tires would actually cut as my 60ft times are already low; I've landed as low as a 1.58x 60ft time, but the deletion of weight could help in overall acceleration time I suppose. I could try clamping my aFe filter to the 034Motorsports silicon tube the next time I'm out at the track and using the bottom airbox as a heatshield to replicate it, but to be honest I'm not sure how inclined I am to do so given the opportunities of possibly heat soaking as you sit in the staging lanes.
    Jul 28 2009
    Philadelphia PA
    What's the curb weigh of an s5 compared to a similar option s4?
    c8 a6 allroad
    Feb 25 2014
    Texas
    Great times!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Nov 29 2013
    Silver Spring, MD
    Keep up the great work, Loe! Just curious, if you did any runs with straight 93?
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Aug 09 2015
    Sarasota, FL
    no, not yet on a dual-pulley set-up. If I end up attempting a pure 93 octane run, I would prefer to wait until winter time so that I can at least obtain a time that would be favorable to a 93 pump user. I did run a 93 pump file for the past 3 weeks prior to my track night on a 30% ethanol blend; I can try that next time out at the track. I suspect that the times will be within .2-.3 tenths of the time in this thread based on logs and the timing targets I was able to hit (so 11.69-11.79 ish @116-117mph in 2900ft. D/A's).
    Aug 09 2015
    Sarasota, FL
    I hear conflicting information such as the S4 being 100lbs or so lighter, but every article I've read says they are very similar.
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Great stuff man, keep it coming!
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Dec 22 2009
    MA
    Quote Originally Posted by Loe View Post
    Good to know, thanks for the explanation. I think I'll just start with a Stage 2 tune + TCU and go from there. Up here in the Northeast we get some pretty low DA's, especially during the early spring and fall. It's rather cool out today and my phone reports 983ft currently. However I remember back in the fall it was ~ -500 ft one night I believe....
    When you run your 93/E85 mix, do you simply whip out your program switcher and click on the Race file? (Assuming you have one with the GIAC tune) Also, how would you rate the daily drivability of your GIAC tune?
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    Great job Loe!
    work hard, play hard[;)
    Aug 09 2015
    Sarasota, FL
    Drivability feels refined like oem, but substantially more power across the rev range. When I look back at my single pulley time and how I ran it without a logging device, I actually think I could have ran an 11.3x in 368ft D/A's knowing now with a logging device on how to properly keep a watchful eye on IAT's prior to the start of any run. So yes, I would venture to say that with simply a GIAC ecu/tcu, D/A's below 1000ft, any form of intake mod, a race file with supporting fuels, you can run mid 11's (11.4-11.6) easily so long as you practice the launch technique. Yes, the GIAC comes with a program switcher; it takes less than 5 seconds of time to switch maps. I use it when I switch down to a lower ethanol blend on pump, however given the extremes of what the car was able to accomplish in 90 degree weather according to my logs and what I feel is a safe ignition correction amount, I'm more inclined to keeping it on my higher ethanol blend + race file the remainder of the summer. Keep in mind that this my particular car/environment conditions, it's best to log via VCDS for your particular set-up.
    Quote Originally Posted by PinoyS4 View Post
    Great job Loe!
    Thanks man! I hope your set-up is running fine as well? Can't wait to see times from you as well this fall!
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    Loe, any chance you quickly describe how and where you did your drilled air box mod?
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by abamfo View Post
    http://www.audizine.com/forum/showth...x-hole-testing
    I drilled it in the same location at audizine member AZT
    May 12 2016
    Thanks Loe, have you done any intake air mass logging? Would be interested in knowing your setup compares with the 1380-1430 kg/h which jran76 logged over 5 runs in 3rd gear for the CTS and ECS intakes
    Aug 09 2015
    Sarasota, FL
    I have not, however I don't think my intake air mass would exceed a true intake such as CTS, ECS, AWE etc etc... IIRC, I think AZT tested a modified airbox + filter + intake tube a few pages into that thread as well and compared it to a true intake.
    I have my reserves on open element intakes, however you know what they say about opinions
    May 12 2016
    Yes, I do ... I ended up going with the CTS intake on my '14 A5 3.0 TFSI, hoping the open element doesn't cause any issues and my exhaust drowns out the wine
