Results 1 to 16 of 16
    Jan 29 2010
    north ga
    Rear Hatch wont open
    So my B6 S4 has had this on-going issue for at least 2-3+ years. When you go to open the rear hatch, it decides to be a dick and wont open. You pull on the handle and you can hear the mechanism try to open but the latch just will not release. Every now and then it will open up, but 90% of the time, nothing. It's especially a problem if it's very hot, cold, or you are in a situation where you REALLY need it to open.
    For the longest time I just assumed it was a bad latch. You can hear it trying to work, but the latch just wont release. Well the part is $100-125 and I'm super stubborn so I have put up with it so far. Well recently I finally spent the money, bought, and installed the part. Once getting everything back together I tested it and NOTHING. I still have the same problem....so $100 down the drain.
    Things to note: Latch is getting power because it tries to function and every now and then will open properly. Also if you pull the emergency release cord behind the warning triangle it will open manually. Lately this has been my go-to method if I really have to use the hatch.
    So Avant experts, any ideas?
    Jan 29 2010
    north ga
    .....nothing, nobody even has a guess?
    I checked and there isn't even a fuse for the hatch like there is every other door
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    interesting...the piece that you replaced, was it just the latch or the mechanism that opens the latch (i.e. some mechanical part)...i would think since you can do the emergency release, but not normal, the machinery/mechanism (i cant think of a better work) that operates the latch is malfunctioning...
    just a thought...throwing something out there as a brainstorm...
    Jan 29 2010
    north ga
    The piece I replaced was the mechanical part
    New one behaves exactly as the old one did. I can even see the latch not fully releasing if I flip it closed by hand while holding the door open. I flip it closed then hit the door button and watch it stutter but not release
    The manual release cord attached to that silver piece to pull the latch open
    Nov 13 2011
    b7 s4 avant
    That's really odd. The only time I've had issues with the rear hatch is when I fried my comfort control module (twice) and most of the time I couldn't get it to open unless I climbed in the back. I wonder if it's a voltage issue. You say there's no fuse for it, so I would be interested to see what module controls it. Given my past history, I figure it would be the ccm, but there might be another one involved as well. Total guess of course.
    I drive a truck now.
    May 15 2009
    Quebec, Canada
    i have the same problem with mine... it happens 3 or 4 times a year and it pisses me off. I think its more of a voltage issue like geebus said, it looks like the power used to open the latch and make the mechanical piece you bought open doesnt ''charge'' enough to make it work. and like you said, it happens when you REALLY need it haha
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Sounds like the actual latch needs to be greased, I just swapped my entire hatch for a European one and I had to reuse my own lock mechanism, wiper motor etc. when I was done reinstalling everything my latch wont slide back the right position, so when you close it the hatch wouldnt close because it was banging on the latch. Try greasing it so it can slide properly
    This car is what I look like on the inside
    Jan 29 2010
    north ga
    I just bought a brand new OEM part to fix my problem, and nothing happened. I don't think the issue is lubrication. I wish it was. I tried spraying it with lube like 2 years ago, and it had no effect on it at all.
    Oct 03 2015
    West Hartford, CT
    my wagon just started doing this... pretty frustrating
    2015 Monsoon Grey S3
    2008 Brilliant Red S4 Avant 6MT @thatredwagon
    Dec 01 2007
    Orange County, NY 10918
    Mine does this when it's warm out. In winter works fine once it warms up or direct sunlight back there it doesn't work. My 03 had a key hole if it didn't work. The 05 has nothing.
    Sent from my SM-G900V using Tapatalk
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Senior Member Two Rings deanjohnson's Avatar
    Mar 23 2012
    2011 mini cooper s, 2013 b8.5 allroad, 2021 C8 RS6
    minneapolis, mn
    Is the little motor that releases the latch integrated into the latch part you posted, or is it separate? If the motor is a separate part, I'd guess that maybe the motor is dying and isn't providing enough torque to release the latch. If its part of the module you replaced, voltage issue sounds like a good place to start.
    Sebring Black C8 RS6
    Moonlight B8.5 allroad
    Cactus B5 S4 Avant - SOLD
    Quartz Metallic C7 S6 | EPL stage 1 ECU/TCU - SOLD
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Lots of talk about this over in the S4 section. Typically it's the solenoid getting weak and needs replacing (the "motor"). B6 and B7s DO have a key hole next to the latch handle so you don't have to crawl into the back to use the emergency release, you just have to get on your hands and knees to see it. My S4 has been doing this forever, but due to crimped wires in the trunk. Haven't given it a second thought since I discovered the key hole.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Three Rings Toronto5.5's Avatar
    Apr 03 2011
    You replaced the wrong part.
    The part is the trunk latch actuator not the trunk latch.
    here is a video of what is wrong: https://www.youtube.com/watch?v=aLF5lzVRWvo
    Jan 29 2010
    north ga
    Quote Originally Posted by earhythmic View Post
    Lots of talk about this over in the S4 section......... Haven't given it a second thought since I discovered the key hole.
    Weird, I don't think I've really ever seen it mentioned in the B6/7 S4 section.
    And I wish I could use a key to open the hatch. My S4 does not have the key hole on the hatch. My A4 Avant does, but not the S4.
    Quote Originally Posted by Toronto5.5 View Post
    Ah........thank you. I wish someone would have told me this long ago. Now I see it mentioned a bunch in the A4 section, but not the S4.
    Is this the right part number for the Avant?
    4B9962115C
    Established Member Two Rings boarderx100's Avatar
    May 25 2011
    Huntington Beach, CA
    I have a B7 A4 Avant and couldn't find the keyhole. I opened the hatch to get a good look and didn't see one..
    Active Member Two Rings xxshor7yxx's Avatar
    Jun 24 2011
    Audi Q5 2013
    North Jersey/NYC
    i had the same problem on my b6 s4 avant, first i changed the trunk latch and still had the problem so i changed the trunk actuator and finally i have a working trunk. hope that helps. idk why but mine doesn't have a key fob to open from the outside i actually had to open it from the inside
