Results 1 to 15 of 15
    Veteran Member Four Rings ballinb5's Avatar
    Jan 16 2011
    CA
    Advice/recommendations on buying A4 Avant
    Hi all - I'm searching for a replacement car for my B8.5 S4 and really like the look and modding potential of the B7 A4 Avant with the 2.0T and 6 speed (manual is a must!)
    Checked a few out online, but they all have oil consumption issues. After some research, it seems that it's pretty common for the 2.0T motor. Any recommendations? How does one diagnose oil consumption if I were to go look at the car? Will a compression or leak down test reveal anything?
    I'm very flexible on color, options, mileage, location etc... as I don't mind slowly buying and upgrading pieces to sline. Just looking for something low, slow, and more space with the avant.
    Anyone know of any good cars around DC area?
    Anything else I should be worried about on this platform? Is there any difference in years 06-08?
    Thanks in advance.
    My current car hehe:
    2021 SQ5
    2008 A4 Avant 6 speed
    Oct 24 2015
    Perth, WA
    You're getting rid of that beauty for a family-wagon !!! Wow.
    My respray thread
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    I can't tell if serious...This is a weird decision indeed.
    Ivan
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    My recommendation in buying the avant is not buying it.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Okedokey View Post
    Mar 24 2013
    Oakdale, CT
    Buy one with oil consumption problems on the cheap. Then you get to build the engine right away.
    -Adam
    Jan 16 2011
    CA
    Serious here. Should've not posted the pic haha... Not sure I need such a nice car as I would get near same enjoyment modding something new and unique. Plus more affordable and convenient with the space.
    Was thinking the same on buying a bad consumption one and putting money aside... Although they're all over $10k either way.
    Is the oil issue really that serious? Does every car have it or are there some that are good buys.
    2021 SQ5
    Feb 15 2016
    Cambridge,Ontario
    Problem with oil consumption is you won't know unless owner discloses. I just bought an a4 myself. Put on 600km since getting mine and has not budged off full yet , so I'm hopeful
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by ballinb5 View Post
    If you don't mind adding oil every so often, there really isn't much to worry about. Some are obviously worse than others though. My last engine burned a quart in less than 300 miles, but that was a built engine and I don't think the rings ever seated properly during break in.
    -Adam
    Mar 01 2016
    San Diego/CA
    I brought a used A4 B7 and I have oil consumption issues. I used to put 1quart per 1000 miles. Till now I found out two places oil was leaking from.
    1. Leaky vacuum pump. Tried re-sealing it but did not helped. So, changed it with new revesion. Now I put a quart every 2000 miles.
    2. Recently found leaky VCG. No outside leak, but oil was leaking into spark plug well internally. Changed the VCG. I will see if my oil consumption reduces.
    Sep 23 2009
    2012 A4 Avant
    Bay Area, Ca.
    I just bought a 2012 avant after doing some research. After two months have had zero consumption problems. Sounds like some 2012's were still affected, but mostly the problems were from ''09-'11. That is what I read....good luck. Go 2012 premium plus s-line with sport pkg
    2012 A4 Avant.
    Sep 23 2009
    2012 A4 Avant
    Bay Area, Ca.
    Sorry mistook b7 for b8. Disregard, good luck though.....
    2012 A4 Avant.
    Veteran Member Three Rings redavant's Avatar
    Jun 17 2014
    California - Bay Area
    First of all, nice looking car!
    I had a 2008 RS4 - it was a really FUN drive. But I am an Avant guy. So, bought a A4 B8 Avant... and love it.
    Sure you've seen this: http://www.audizine.com/forum/showth...sifieds-Thread! - there a number of B7s S4 6MT for sale. Take a closer look!
    Also, where did you get the grey/silver-colored RS4 mesh front grill? Did you paint yourself or bought it?
    Misano Red 2011 B8 A4 Avant S-Line Prestige
    My Build | AvantGarde M510 265/30/19 | RS4 grill | Euro Tail Lights | RS6 Steering Wheel | S-Tronic shifter |
    Feb 05 2011
    A3 (sold), 2x B5 a4 avant (sold), b6 avant (sold), b7 avant (sold), b8 S4 avant swap. RS4 avant swap
    phila/PA/Northeast
    Keep existing car and get roof box?
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    i may consider selling my black b7 ti avant 6sp 2.0t. im not local to you however.
    PM me if you might be interested.
