Results 1 to 2 of 2
    Sep 24 2013
    orlando/ baltimore
    need help with the k line?
    i installed a aftermarket radio in my car and need to fix the k line now so i can use my obd2 port again. so can some tell me what wire i need to cut or remove( like the color or spot on a symphony radio in a 2000 a4) and from which harness should i do it from the original or from the aftermarket harness?
    Oct 30 2009
    Miami, FL
    The aftermarket harness adapter will have a jumper wire between 2 pins, usually blue. Cut the loop and you're done.
    Sent from my Moto G 2014 using Tapatalk
    2018 S5 Coupe - stock for now
