Results 1 to 35 of 35
    Dec 16 2014
    Dealer Parts vs Aftermarket - Timing Belt, Water Pump, Motor Mounts
    I am going to put my baby in the shop to have the timing belt, water pump and motor mounts replaced. (I get a vibration through the entire car when I accelerate consistently, like getting on highways.) I was told that they could "most likely" knock off a couple hours labor if they do the mounts at the same time opposed to a second job. They want $200+ per mount and about $80 for a snub mount and about $550 in parts for the timing belt and water pump after all the seals etc.
    Is it worth purchasing after market parts for them to install and forfeit any type of dealer parts warranty?
    My B6 is completely stock and will most likely remain that way while I have it. I drive about 20k a year and need it to be reliable. Figure RS mounts will probably be too stiff.
    034Motorsport's Density Line Mounts
    ARP Snub Mount
    ECS Tuning Timing Belt Kit w/ Gates Racing Belt
    Also, should I have them put in a poly torque dampener?
    Thoughts?
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    please tell me those prices aren't just labor... Thats insane for mounts...
    B5 S4 Febi are really good for the b6. Almost like stock but much more durable.
    If you do get an aftermarket timing belt kit, make sure the waterpump isnt GEBA, they are known to fail and grenade engines.
    19' Glacier S4 Black Optics
    Nov 10 2015
    Sudbury, ON
    Order all the parts on your own, then bring car in, with all needed parts in the trunk. You will save a decent amount of money.
    Snub Mount - $34.00 http://www.apikol.com/index.php/prod...nub-mount.html
    Be careful of waterpump, GEBA ones seem to be seizing left, right and center.
    Also, if you want to go big with the mount upgrades, go 034 street density motor mounts, trans mount, and rear diff insert. Then email 034, they will get you a little bit of a better price, for a "package" deal. Otherwise Get some B5 S4 mounts, good option: https://www.ecstuning.com/Audi-B5_S4...Mounts/ES2713/
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Jan 24 2008
    Pennsylvania
    If you are keeping the car, and can afford the cost of OEM parts, that is almost always my suggestion. Especially for critical function parts like water pumps, timing tensioner, etc. Or at least go for the non-Audi branded part that is made by the same manufacturer. of the Audi-branded part.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Nov 10 2015
    Sudbury, ON
    Quote Originally Posted by Turbavanttro View Post
    For T-belt, tensioner, Waterpump, and pulleys, I would agree, OEM is a decent option. But aftermarket belts like gates are just as good, or better, for less money. And as far as motor, snub, tranny, etc.... mounts, aftermarket is far superior
    Dec 16 2014
    Thanks for the advice guys. Yea I've seen that about the GEBA pumps. Id like to stay OEM with anything internal, that way its on the dealers hands if anything fails.
    I'm going to get an itemized invoice from the dealer and see what the difference is cost will be.
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Quote Originally Posted by JKCutler3 View Post
    I wouldn't replace the mounts unless you can reasonably determine they have failed. Same thing for the cam and crank seals. I would also insist on bringing your own parts and let the shop owner/manager you are an enthusiast.
    Dec 16 2014
    Quote Originally Posted by Gin+ View Post
    The mounts have definitely failed. Oil leaked out of the one and the other appears to have dry rot/cracks.
    I spoked with my rep at the dealer today. When I get the estimate I'll post it up in case anyone was curious about costs at the dealer.
    Aug 27 2013
    Philly
    Dealer + those parts is gonna be a scary high bill. I'm guessing $2,500+.
    Apr 07 2011
    I paid ~$2,000 to have my timing belt job done at the dealer a few years ago. I have since taken up the task on my own. Ridiculous amount of money to spend on a job that is not that difficult.
    Dec 16 2014
    Subtotal Sales Tax Total
    Timing Belt and Tensioner - Replace
    TIMING BELT, TENSIONER, ROLLER, WATERPUMP - $1017.25 5Hrs Labor - $468 in Parts / $550 in Labor
    General repair
    MOTOR MOUNTS - $975 $460 in Parts / $515 in Labor
    General repair
    SNUB MOUNT -- NO CHARGE LABOR WITH TIMING BELT - $28 0 Labor
    $2020.25 Total
    Looks like 4.5 hours of labor to do the motor mounts while you're already tearing apart the front end? Doesn't make sense to me. I'll buy the 034 mounts off ECS and look for another way to get them installed.
    Timing belt - $468 in parts compared to $300 for the ECS kit. I'd essentially be paying $168 for the warranty by the dealership. And $550 in labor of course.
    Thoughts on OEM vs Aftermarket Fuel Filters? Thinking about a MANN from Advanced but I'm not sure about quality.
    Aug 26 2005
    MANN filters are OEM quality.
    Vorsprung durch Technik
    Aug 26 2007
    General repair
    General repair
    $2020.25 Total
    The timing belt price at the dealer really isnt too bad and am honestly quite shocked. Most shops charge $800-$1000...
    The motor mounts though... Insane haha. Its like a 1Hr job even if you dont touch anything in the engine bay.
    May 05 2009
    CO
    Have you had bluewater quote this?
    Veteran Member Four Rings V70R's Avatar
    Feb 14 2015
    PDX, OR
    Mann fuel filters for b6 platforms have a Chinese COO and increased audible sound when installed, and are avoided by most Indy shops in Portland. Kayser or KYG fuel filters are the OE supplier and the only filter I would consider. Mann oil, air and cabin filters are OE quality, and recommend when given the option for purchase.
    Xlite w/ 11spd Campy Record- 2005 Dolphin Grey Ultrasport Avant 6MT-- 2003 S6 — 2007 XC70
    Aug 26 2005
    Quote Originally Posted by V70R View Post
    I did not know this about the MANN fuel filters. There should be German made MANN fuel filters in the retail channel as well. Thanks for the correction.
    Jun 26 2015
    Tampa, FL
    General repair
    General repair
    $2020.25 Total
    Those parts prices are crazy. $460 for motor mounts, and $28 for a snub mount? OE mounts are only $300 on ECS. As others have said, get the 034 engine mounts. You should be able to get free shipping on all of your parts from ECS if you get the ECS snub mount (yes, they carry the 034 parts you'll need too). Either contact ECS and get them to change out the GEBA pump, or piece it together yourself.
    Dec 16 2014
    Quote Originally Posted by 2fast4u66 View Post
    No I haven't but I'll damn sure give them a call
    That's why I asked. When I saw "Made in China" I was a little skeptical. Thanks for the heads up!
    Feb 14 2015
    PDX, OR
    For sure! I see you're in Denver, RM European is pretty close to ya, they're an awesome source and have great prices for OEM or genuine Audi parts.
    Edit- attached a late B6 with internal FPR screenshot from RMeuropean.com for $35.28
    Dec 16 2014
    Picking it up tomorrow!
    Apr 03 2016
    Up North
    I can only echo the use of OEM parts. I went for that $300 ECS timing belt kit. Crap ass Uro tensioner failed at 28,000 km. I got to do the job all over again to replace it. If you are paying someone else to wrench then its hardly worth it. Not to mention that it came close to making my pistons meet valves. It was two teeth off when I replaced it. Still mad at myself for cheaping out. Never again.
    Dec 16 2014
    Just had them do my timing belt and water pump for just under $1k. However, I had a fault code for the thermostat when they first checked it. After the install, the car is now overheating and they want another $500 for the thermostat or give it back to me overheating...... Car was not overheating when I brought it to them....
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Was the thermostat changed with the service?
    Sent from my DROID Turbo 2
    Dec 16 2014
    Quote Originally Posted by imnuts View Post
    Nope, told me about the code after the belt and water pump were done.
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    That sucks what was their response when you told them the car did not have that issue when it was brought in?
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by rocket1420 View Post
    Agreed, very high quote IMO. Just FYI, you can get B5 S4 mounts for your car for <$50/ea (Febi or Meyle) - (OE S4 mounts for $108 @ ECS BTW). The install is easy (<1hr) and you have to take the snub mount off to do it anyway. I personally wouldn't pay someone to do that work when you could save hundreds versus where you are taking it apparently. If you do do mounts yourself, do yourself a favor and cut the posts down a little bit, you wont have to raise the engine as high to get them in/out this way and are less likely to "upset" any of your vacuum lines etc. in the process.
    Dec 16 2014
    Quote Originally Posted by jayiszraw View Post
    Either I could have it back overheating or pay out another $500 to have thermostat and j-plug replaced. They didn't care it wasn't happening prior to bringing it in. Said it might have been stuck open.
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    this is what happened during my own t-belt service doing it myself. the thermostat failed for some reason.
    you should fight that tooth-and-nail - you aren't paying them to break stuff on your car.
    Aug 27 2013
    Philly
    Damn that blows. Take it back, fix it yourself and contact AoA.
    Aug 12 2009
    Dirty Jerz
    Odds are that if you didn't have anything done to the thermostat, and I'm pretty sure it isn't touched during a service, the shop isn't going to cover it. Maybe it wasn't overheating when it went in, but how do you know they broke your thermostat? And what makes you think they did for that matter?
    Aug 26 2005
    When guys do this, is cuts a significant part the indy shops profit performing the repairs. It's the same thing as asking for a big discount on labor, possibly resulting in a net negative profit for the the work done. Some shops will refuse to accept work with parts already provided. Other shops may quote a higher labor charge per hour. Most shops consider providing your own replacement parts as rude and inconsiderate business practice. It will also be harder establishing a positive business relationship with the shop since it is viewed as taking advantage of a shops good will toward providing excellent service quality and good value for customers.
    Aug 10 2011
    330i ZHP
    Agreed, but it also allows the owner to have the exact parts they want installed, not the parts the indy shop can get away with the highest mark up on. I don't mind my guy charging more for labor, which he doesn't, if I bring my own parts; it's still cheaper on my end and I know exactly what was installed. Allowing owners to provide their own parts has the added benefit of me deciding to use him exclusively for service I don't want/have time to perform myself for that reason, and not choosing to shop around for the best quoted price.
    Aug 27 2013
    Philly
    Quote Originally Posted by MacFady View Post
    This! I know for a fact that most parts indy shops are using are the ones they make the most money on. I mean, that's the logical business decision. When was the last time you heard of a mechanic calling someone up and saying, "Hey, we read you can use b5 S4 engine mounts that are significantly cheaper and supposedly better instead of the same fluid filled mounts you have now. This'll knock $100 of the quoted price". The answer is never. That never happens. As someone who cares about what parts are on my car, I would never let someone else make the decision on parts. That's a whole lotta Nope for me.
    Apr 16 2015
    CNY Syracuse
    I don't need a lesson in values and I understand how it works. Don't like the terms then don't sign the contract.
    Dec 16 2014
    I drive 100+ miles a day. I keep an eye on my temp gauge constantly since my coolant flange blew open last December. My a/c compressor was replaced by the dealer in March, and there was no mention of any coolant issues or codes. I'm not saying they "broke" it, but to get a call, "hey you can come pick it up, but its overheating, or you can shell out more money to have it fixed" is kind of shitty. (They did work with me on price, was $968 for the OEM timing belt/water pump and wanted $500+ for thermostat, but he agreed to come down to $1,400 total prior to doing the work on the thermostat)
    Additionally, there were still air bubbles in the system after they returned the car. I have put in an entire bottle of coolant (mixed 50/50) since I've had it back. I'm going to keep an eye on this as I heard conflicting stories when I asked if they did a compression check after the car overheated.
    Regarding brining your own parts, I think it is different shop to shop. I asked them about having my motor mounts replaced and they had no problem charging 2-2.5hrs labor if I brought my own mounts.
