Results 1 to 21 of 21
    Senior Member Three Rings CapnToll's Avatar
    Apr 18 2014
    '17 C63S AMG Coupe, '96 Acura Integra
    Alberta, Canada
    Octane Booster - Local gas station out of 93/94!! APR Stage 2+
    So Petro Canada gas stations across western Canada have run dry which is where I get my 94 fuel. I'm almost empty and too far away from a Husky station that has 94.
    Any recommendations on brand of octane booster that I can put in my empty tank and then fill up with 91?
    Thanks
    2014 Audi S5 FOR SALE: http://www.audizine.com/forum/showth...ll-the-goodies
    DSG - Phantom Black - Black Nappa Leather w/ Chestnut Brown Inserts - Beaufort Wood Inlays - Sports Diff - Adaptive Dampers - APR Stage 2+ Pulley/93 Tune - CTS Intake w/ Heat Wrap - 323whp @ 3000' (AWE intake)
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    Ya, E85 if you have any up there in Canada.
    Apr 18 2014
    Alberta, Canada
    Don't think there's anything close to me. My range is down to nothing now after driving around to both 94 locations in my area just to find all the pumps are roped off.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    3-4 gal of E85 and 91oct 10%E will get you over 93 octane
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Apr 18 2014
    Alberta, Canada
    Yea just don't have access to E85. Was thinking about various boosters like Lucas Oil that claim to raise octane 3 points
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    Can you get ethanol from a local hardware store?
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Apr 18 2014
    Alberta, Canada
    Suppose I could look around or pick up some race gas to at least get me to the tuner and flash to the 91 tune.
    Jan 04 2013
    Phoenix, az
    If they will let you get some race gas in on container some 103 would get you buy.
    Apr 11 2012
    if you don't drive it hard, shouldn't you be ok on 91?
    Apr 18 2014
    Alberta, Canada
    I'd hope so but I really don't want to do anything that will make the current program freak out with some of the APR issues that have been going on.
    Oct 13 2009
    MN
    Quote Originally Posted by CapnToll View Post
    It'll adapt. Just drive'r easy.
    Jul 28 2014
    WI
    http://torcoracefuel.net/pro-accelerator.html
    I've heard this stuff actually works, I haven't tried it myself though. It would be interesting to see some before and after logs.
    2015 Glacier Metallic White S4
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Put enough 91 to get you down the road to another potential station if you're that worried and drive like a cop is behind you
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Quote Originally Posted by K1aus View Post
    it works to a certain extent if mixed properly, the only issue with it is that it's not a stable additive, it'll eventually separate unless it's constantly mixed. It also leaves a rusty residue inside the combustion chamber, through the exhaust ports, all the way out to your tail pipes and coat your bumper with a similar color.
    really the only trued/true octane booster we have available would be ethanol.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Apr 14 2015
    United States
    toluene from a paint store works should be fine for short term use I have used in my old supra it was great.
    http://www.rx7club.com/rotary-car-pe...ne-etc-339648/
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by dashotgun View Post
    I use to use that in my water meth injection sometimes lol
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Toluene will boost your octane.. Check this out: http://www.gnttype.org/techarea/misc/octanebooster.html
    Apr 18 2014
    Alberta, Canada
    Thanks for the references guys
    Oct 06 2014
    Cleveland, OH
    Xylene works too. Used to run that in my Talon on occasion. Sherwin Williams paint stores have it.
    Apr 05 2016
    Portland, OR
    Just FYI it should work on 91 you will just have a considerable lack of power due to the ECU constantly adapting.
    Just ask anyone on the West coast of the US who have flashed a 93 tune when we only have 91 available.
    I would put enough 91 in the tank to make it to the next gas station then fill-up with your normal stuff.
    Geoff
    Apr 18 2014
    Alberta, Canada
    Thanks - may have found someone willing to give me a lift to fill up a 5 gallon gas can which will be more than enough to get me back there to fill the rest of the tank.
