Results 1 to 10 of 10
    Established Member Two Rings cdh9400t's Avatar
    Feb 06 2014
    Ohio
    Oil in drivers side intercooler
    I'm working on doing my timing belt this weekend and drained a bit of oil out from the drivers intercooler. Past experience tells me turbo oil seals. But a search shows this is common and a catch can is needed. Any thoughts? The car runs and drives great. No exhaust smoke, no vag codes.
    May 20 2010
    Quite common and "normal". I assume you have to add oil at some point between oil changes.
    Catch can is not required, per se, but some folks recommend it. Biggest issue with catch cans are when you forget to drain it.
    Feb 06 2014
    Ohio
    Yes I add oil. Usually 1-1.5qt in 5k miles. Good to know. I will clean her up and get it all put back together. Thanks..
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by cdh9400t View Post
    That seems to be quite a bit of oil usage. I don't have to add any to mine.
    My respray thread
    Feb 06 2014
    Ohio
    The amount of usage has not changed in the last 30k miles. I have owned turbo cars that use almost a qt per 1000 miles. Dealer said that's within spec. So I'm not worried at all with only a qt between changes.
    May 20 2010
    Quote Originally Posted by Okedokey View Post
    You should be the one to consider yourself lucky. Almost everyone stateside has to add oil. I think Adam (aluthman) is close to fixing his consumption issues, but that required rebuilding the entire way.
    Jun 17 2013
    jersey city nj
    Yep then in the winter time it freezes
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by vce1232000 View Post
    Not here, 22oC and everyone is losing their mind over winter :)
    My respray thread
    Oct 23 2015
    Australia
    Haha don't mention what else is happening here weatherwise lol
    Are you surviving it ?
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by Ringsby4 View Post
    Yeah mate, apartment 4 floors up, good view, dry and warm.
    You?
    My respray thread
