I have been looking at photos and posts to determine where my leak could be coming from. I have a CPO 2013 S4 with 72k. I did an oil change about 3k ago, the drain plug is fine. I am getting drips in the back of the engine pooling up right at the rear screws of the belly pan. I took off the pan and its only wet in the rear. When replacing the oil, I did replace the O ring and the internal gasket.
I am thinking its the oil filter gasket, just not sure. Have any of you had this problem before? I was going to clean everything up, replace the oil, filter and gaskets and check again.
