Results 1 to 8 of 8
    Mar 26 2016
    West Midlands - Staffordshire
    Pics of 19x8.5 wrapped in 255/35/19? Need Help!
    Hi
    I started collecting parts for my B8 a few months back, with my car going back to Audi for a rebuild due to the oil consumption i couldn't modify the car at all as the dealer would refuse to pay out for the bill. However the time has come, its booked in for next week and I'm very eager to start the changes as soon as i get it back.
    I recently brought some peeler reps for dirt cheap, 19 x 8.5 ET45 however they have been wrapped in 255/35/19's. Ive also brought some H&R 30mm springs as over here in the UK they don't sell the OE Sports springs set :/ Ive also grabbed some 10mm hub spacers to make them slightly more flush making them ET35.
    I was just wondering does anyone know if my tyre size would cause an issue being 255? Should i go 235 instead?
    If anyone has any pictures of a familiar setup that would be great!
    Thanks
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    I would say that is the correct tire size but if you like more stretched than 235 will do. I have 255/19/35 on OEM S5 19x8.5.
    - iKe -
    2011 S5
    2011 A4 Avant
    Mar 26 2016
    Ahh ok, ill keep them as they are. I don't fancy stretch as the road conditions over here are terrible.
    thanks for the help!
    Mar 20 2016
    Elmira, NY
    I'm running 19x8.5 et 43 with 255/35/19 with a 10mm spacer front/8mm spacer rear and have no issues being lowered.
    Dec 27 2014
    United States
    I have 19x8.5 et 35 with 255s. No issues. They look great too.
    Dec 01 2011
    255/35/19 is the OEM tire size, you should have no issues at all, and it's the perfect balance between comfort/practicality and looks. doesn't look too thin but also not too fat.
    i have OEM peelers 19x8.5, with 255/35 tires and they've been great, i don't think i'd run any other size, need as much protection as you can get for the wheels on these bad roads.
    IG @theshawon
    Veteran Member Three Rings PBKIDD24's Avatar
    Apr 30 2015
    Quote Originally Posted by Liquid Smoke View Post
    +1 I run 255/35/19 PSS on my oem 19x8.5 rotor wheels
    2015 S4 P+ Daytona Grey Pearl Effect
    APR / Milltek / Bilstein / Eibach / 034Motorsports
    Build ThreadInstagramFlickr
    Past Cars: 2015 A4 Build Thread
    Established Member Two Rings kiw1's Avatar
    Mar 29 2016
    2022 BMW X5
    Santa Monica, CA
    Quote Originally Posted by PBKIDD24 View Post
    +1 I'm running PSS with 19x8.5 ET35 RS5 reps. Stance is great.
    2012 A4 Avant - APR Stage 2, JHM FMIC, EuroCode Test Pipe, Front and Rear Sway Bars, Bilstein PSS10, CR15, ECS Turbo Inlet Hose, aFe, RS Front Grille
