I'm a new member of this forum so forgive me if i'm posting this in a wrong section or if i seem to be an amateur.
Before you Start telling me that this is a common issue and that the solution is all over the internet let me tell you that i have read all those posts and Have tried Every solution , literally everything but nothing works.
about 6 months ago My Brake/Turn Signal Started Turning off every while and then, Now its always Instant as soon as i Turn The Indicator Off it Flashes for a Second and then I Get the Alert on the Screen.
ofc i checked the Bulbs, the bulb holder, the light, The grounding, the Fuses all seem to Good.
I Tried adding another Ground wire Still no Success.
I even Changed the Light and the holder But after a week it stopped working, Waste of money....
Tried with another light and Same issue Appears.
took it to so many Garages no one can find the Issue, No one!
Suggested by one of the Audi Technicians here i Ended up ordering Another Comfort Control Module From Ebay and I Still Have the Same Issue but only For the Turn Signal, Brake light seems to be fine now I guess because its a german CCM and My CCM was American,
I've Even Tried With Different Comfort Control Modules Still the Same thing. so its obviously not From that either.
So i got a VAG COM Cable and Did the Diagnostics, Came up With alot of Faults, Cleared it, Drove around and did The Full Test Again and this is what it came up with.
I did have a Burn Mark at the Ground Connection Point to the Bulb Holder, Already Cleaned the contacts Even changed the Cable and Connector but no Success.
Its a very Unusual Issue Since Most of the people who had this problem Either Solved it with Cleaning the contacts, Adding another ground wire or Even changing the Whole Holder and light but surprisingly none of that works for me.
I'm Desperate for Some Help This issue is Killing Me , I live in Dubai and there aren't Many Audi Garages here and the Ones that actually know their Stuff Are very Few and Very Expensive.
Thank you.
Code:
Chassis Type: 4F (4F0) Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53 55 56 61 62 65 72 77 VIN: WAUDH74F66N174178 Mileage: 241190km-149868miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 4F1 910 559 E HW: 4F1 907 559 A Component: 3.2l V6 FSI 0070 Revision: --H15--- Serial number: Coding: 01050109190F0120 Shop #: WSC 02325 785 00200 VCID: 2D56919BB4029956C6-8078 1 Fault Found: 005715 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 241172 km Time Indication: 0 Date: 2016.06.02 Time: 17:47:14 Freeze Frame: RPM: 896 /min Mass Air / Rev.: 92.7 mg/str Temperature: 58.5°C Idle Load: 12.9 % Speed: 0.0 km/h Readiness: 0000 0100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F2 910 156 D HW: 09L 927 156 A Component: AG6 09L 3.2 FSI USA 0020 Revision: --H01--- Serial number: 4163925 Coding: 0000002 Shop #: WSC 02325 785 00200 VCID: 26446EB791F4AA0E07-8072 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H05 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020895 Shop #: WSC 02325 785 00200 VCID: 2D56919BB4029956C6-8078 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 244 Mileage: 241172 km Time Indication: 0 Date: 2016.06.02 Time: 17:47:14 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4282 Hex Value: 0x0024 Hex Value: 0x019D Hex Value: 0x00FF ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H31 0210 Revision: 27120501 Serial number: 10601000386676 Coding: 0000011 Shop #: WSC 08316 444 54462 VCID: 63C237A3A2461F2620-8036 Subsystem 1 - Part No: 4F0 910 131 J Component: FBSAUDIC6 EZS H45 0080 Subsystem 2 - Part No: 4F0 910 220 A Component: FBSAUDIC6 IDG H39 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F0 910 731 B HW: 4E0 035 729 Component: Interfacebox H43 1190 Revision: 00000000 Serial number: 303CN067519905 Coding: 0000003 Shop #: WSC 02335 785 00200 VCID: 214E7DABF8DA4D3672-8074 Subsystem 1 - Part No: 4F0 910 609 E Component: Bedienteil MMIC6H08 0050 Subsystem 2 - Serial number: 00000000370580 Subsystem 3 - Serial number: 0122.03.060000000100010755˙ Subsystem 4 - Serial number: 010755˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F1 820 043 S Component: KLIMABETAETIGUNGH12 0170 Revision: 00000030 Serial number: 00000030110537 Coding: 0524326 Shop #: WSC 02325 785 00200 VCID: 5BB20F439A3627E668-800E 1 Fault Found: 00256 - A/C Pressure/Temperature Sensor (G395) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 245 Mileage: 241177 km Time Indication: 0 Date: 2016.06.02 Time: 17:51:50 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 D HW: 4F0 907 279 Component: ILM Fahrer H15 0190 Revision: 00000000 Serial number: 4F0907279 Coding: 0014123 Shop #: WSC 02335 785 00200 VCID: 2A5C9A8785EC8E6E23-807E Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB Component: Wischer AudiC6 H05 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH12 0090 Coding: 00141886 Shop #: WSC 02335 2 Faults Found: 01494 - Bulb for Parking Lamps; Left (M1) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 205 Mileage: 241172 km Time Indication: 0 Date: 2016.06.02 Time: 17:47:00 01498 - Bulb for Parking Lamps; Right (M3) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 205 Mileage: 241172 km Time Indication: 0 Date: 2016.06.02 Time: 17:47:00 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 Revision: 00000000 Serial number: AUZ5ZBF7271978 Shop #: WSC 00000 000 00000 VCID: 1B324F43DAB667E6A8-804E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 F HW: 4F0 959 655 A Component: 66 AIRBAG AUDI8RH29 0300 Revision: 14H29000 Serial number: 00359D0B635C Coding: 0013878 Shop #: WSC 02325 785 00200 VCID: 2A5C9A8785EC8E6E23-807E Subsystem 1 - Part No: 4F0 910 339 A Component: BF-Gewichtsens. H02 0050 Subsystem 2 - Serial number: 6332CSME111D096D5 Subsystem 3 - Serial number: 6342CSME1121300ER Subsystem 4 - Serial number: 6352QSME0C2244539 Subsystem 5 - Serial number: 6362QSME0D0D0B25M Subsystem 6 - Serial number: 63734SME0B721857% Subsystem 7 - Serial number: 63834SME0C1849755 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90025060740625 Coding: 0002041 Shop #: WSC 02323 785 00200 VCID: 66C42EB751746A0EC7-8032 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 A HW: 4F0 920 980 N Component: KOMBIINSTR. M73 H17 0660 Revision: 00200000 Serial number: 4PY35FP36 Coding: 2129263 Shop #: WSC 08101 444 83282 VCID: 214E7DABF8DA4D3672-8074 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H11 0070 Revision: 11 Serial number: 13008063180132 Coding: 6CFE73CD1B3104 Shop #: WSC 02334 785 00200 VCID: 275A63B396FEB3063C-8072 1 Fault Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 204 Mileage: 241172 km Time Indication: 0 Date: 2016.06.02 Time: 17:47:14 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4F0 910 760 HW: 4F0 959 760 Component: Sitzmemory FS H04 0050 Revision: 00000000 Serial number: 00000000896400 Coding: 0082946 Shop #: WSC 02334 785 00200 VCID: 61CE3DABB85A0D3632-8034 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 N HW: 4E0 919 887 C Component: MNS US H45 0740 Revision: 00000000 Serial number: 355CV067563925 Shop #: WSC 02323 785 00200 VCID: 3878B0CF4B402CFEA5-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 793 E Component: TSG FA H12 0120 Revision: 00000000 Serial number: t4G Coding: 0035563 Shop #: WSC 02327 785 00200 VCID: 2C509C9F8F18905ED1-8078 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H22 0170 Revision: 01700022 Serial number: 01010095080000 Coding: 0393861 Shop #: WSC 02335 785 00200 VCID: 2E549697B904E24EFF-807A 2 Faults Found: 01501 - Bulb for Blinkers; Rear Left (M6) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 129 Reset counter: 205 Mileage: 240899 km Time Indication: 0 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 94 Reset counter: 205 Mileage: 240899 km Time Indication: 0 Date: 2016.05.25 Time: 17:10:40 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F0 910 223 A HW: 4F0 035 223 A Component: DSP-High C6 H09 0140 Revision: PROD_01 Serial number: 00000000207825 Coding: 0000016 Shop #: WSC 02323 785 00200 VCID: 1C304C5FDFB860DEA1-8048 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 B Component: ILM Beifahrer H10 0080 Revision: Serial number: 00000000022121 Coding: 0002114 Shop #: WSC 02323 785 00200 VCID: 5EB40657892432CE0F-800A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 E HW: 4F0 959 792 E Component: TSG BF H12 0120 Revision: 00000000 Serial number: YeG Coding: 0035563 Shop #: WSC 02327 785 00200 VCID: 2C509C9F8F18905ED1-8078 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.clb Part No SW: 4F0 910 801 A HW: 4F0 907 801 Component: EPB CA3C0040 H03 0040 Revision: --H03--- Coding: 0005022 Shop #: WSC 02324 785 00200 VCID: 1E344657C9A472CE4F-804A No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 F HW: 4F0 035 541 B Component: TUNER EU/US/RDW H42 0480 Revision: 00000000 Serial number: 394C-067639284 Coding: 0000002 Shop #: WSC 02323 785 00200 VCID: 234277A3E2C65F2660-8076 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 795 E Component: TSG HL H21 0050 Coding: 0035370 Shop #: WSC 02327 785 00200 VCID: 2E549697B904E24EFF-807A No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl Part No SW: 4F0 910 273 B HW: 4F0 907 273 A Component: Reifendruck 3 H05 0100 Revision: 00050100 Serial number: 00000700019850 Coding: 0062221 Shop #: WSC 02334 785 00200 VCID: 224C72A7FDDC562E6B-8076 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 E HW: 4F0 959 794 E Component: TSG HR H21 0050 Coding: 0035370 Shop #: WSC 02327 785 00200 VCID: 2E549697B904E24EFF-807A No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 B HW: 4E0 862 335 Component: Handyvorb2 H11 0440 Revision: 00000000 Serial number: 00000007536118 Coding: 0010900 Shop #: WSC 02335 785 00200 VCID: 224C72A7FDDC562E6B-8076 No fault code found. End-------------------------(Elapsed Time: 03:24)--------------------------
