Results 1 to 3 of 3
    Junior Member Two Rings
    Dec 26 2012
    Bwn
    Help with Fault codes
    Hello,
    Long time lurker from Brunei. First post. Have a B8 S4 and recently got EPL stage 1 and have been getting engine fault codes. Have been talking to Tony and said the Boost Pressure and MAP errors maybe tune related. I know the guys at EPL can get busy and with the time difference it can be a pain to get in touch. So i figured might as well post here. Can anyone help me with the oxygen sensor fault codes? Do I need to replace them? Part numbers would be helpful as well. Fault codes below. Thanks!
    Address 01: Engine (J623-CAKA) Labels: 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 HW: 8K0 907 551
    Component: 3.0T SIMOS84 H06 0005
    Revision: --------
    Coding: 0104000C180F0128
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM30TFS8K0907551 A01007
    ROD: EV_ECM30TFS8K0907551.rod
    VCID: 6ED3EC55B135C84E9C-803A
    4 Faults Found:
    6429 - Oxygen (Lambda) Sensor B1 S2
    P0136 00 [096] - Malfunction in Circuit
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 111880 km
    Date: 2016.05.18
    Time: 16:22:18
    6430 - Oxygen (Lambda) Sensor B2 S2
    P0156 00 [096] - Malfunction in Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 111880 km
    Date: 2016.05.18
    Time: 16:22:18
    9779 - Boost Pressure
    P0235 00 [237] - Regulation Range not Reached
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Mileage: 111611 km
    Date: 2016.05.07
    Time: 09:50:09
    6307 - MAP/MAF <-> Throttle Position Correlation
    P0068 00 [096] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 10
    Mileage: 111611 km
    Date: 2016.05.07
    Time: 09:50:09
    Readiness: 0000 0000
    Dec 26 2012
    Bwn
    Anyone?
    Sep 12 2019
    CA
    Ever figure it out?
