SOLD
Really really don't want to sell this but I could use the money right now. Will most definitely be purchasing one again once I can afford a new clutch and lightweight singlemass flywheel, to reduce the chatter they are known for.
$300 shipped, lowest I've seen them for is $354 on ebay retail is usually around $500.
This is the part number for the one being sold MFG# 551211
http://www.uspmotorsports.com/Engine...i-2.0TFSI.html
You'll need to purchase new bolts and not reuse your old ones as they are "stretch bolts" and ment to be torqued down only once.
Some info for those not familiar with Fluidamprs, though everyone should have heard of them as they are widely used on all types of vehicles and engines with great results
http://forums.vwvortex.com/showthread.php?4399643
http://forums.vwvortex.com/showthread.php?4421682
"Benefits of the Fluidampr
The Fluidampr replaces your crank pulley to control the harmonics through all RPM ranges of your engine. The precision machined and balanced internal inertia ring inside the precision machined and balanced housing is constantly shearing through the silicone while the engine is turning, tuning to the harmonic frequency bandwidths that your engine is producing real time. Rubber (elastomeric) dampers are only tuned for a specific narrow bandwidth of harmonics and they cannot tune up or down to what your engine is producing. They also wear out and have to be rebuilt or re-tuned frequently. Our Fluidampr products never wear out or have to be re-tuned, as they are constantly balancing the engine to max efficiency via the internal inertia ring. Fluidampr also helps to calm down the chatter associated with double disc clutches.
Decreased engine vibration.
No more flywheels, crank trigger wheels, or timing gears falling off of the crankshaft.
Decreased "Clutch/Gear Box Chatter" which is caused by lightweight single mass flywheels.
Reduction in rpm drops when shifting in a competitive environment.
Gains of 3-10whp and 5-13ft/lbs. torque depending on your current setup.
An overall more efficient and reliable engine.
Manufactured by Vibratech Inc. the leader in engine dampers"
