Results 1 to 12 of 12
    Active Member Two Rings AudiMaster1GER's Avatar
    Sep 20 2006
    B5 RS4
    Germany
    B5 S4/RS4 Eurofighter teaser vids from Germany, 210 mph Autobahn action included
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    R
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Seen a couple of them before but always good to watch again. That car is quick.
    Apr 02 2015
    Boston, MA
    In the second link posted in the pull at the beginning of the video the car bangs and sounds like a gunshot when it shifts. How do you get that sound? Is it just tuned to run richer on the overrun so the unburnt fuel ignites in the manifold? Or does it have to do with less back pressure in the exhaust?
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by B5ston View Post
    Im guessing thats the antilag between shifts.( no lift shifting) knowing it sounds the same as when he uses the launch controll
    Apr 02 2015
    Boston, MA
    I have no lift shift on my car and it doesn't make that sound although I havn't gotten to installing my new downpipes yet so it only has an aftermarket catback. Also I got a ride in a friends abarth and it makes the same sound on shifts though far less aggressive and he doesn't have no lift shift and has a stock exhaust system.
    Aug 04 2014
    Gloucester MA USA
    I know wjat poping your talking about. My buddies straight pipe mini cooper s does it very loud (still not as loud as the s4 in video haha) I think you are right about being extra fuel and no cat converters/ wide open exhaust.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    It's all in the tune. Have you heard a new f-type? It's awesome but it'll blow your eardrums out
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Love this car
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Sep 20 2006
    B5 RS4
    Germany
    Usually the performance enhanced cars have bigger fuel injectors pumping more fuel into the burning chamber, so maybe slightly on the richer side. Also the cats have probably been removed which allows unburned fuel, which ignites on the hot downpipes and exhaustpipes, to explode unhampered with the force of the explosion going straight out of the endpipe. The screen type structure of the CAT acts like a muffler and breaks up those explosions, which prevents that effect. Sometimes flames even come out of some exhausts. Not street legal though. Only for racing.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    ^^^ This my tial 605 car with 3" dp's
    and 034 exhaust did it even without NLS.
    As long as I was banging gears/red lining
    I was shooting fire balls. The higher power
    cars do it alot easier than a stage 2 s4. Bigger
    injectors, turbos, ETC.
    Registered User Four Rings
    Sep 01 2013
    Sweden
    Quote Originally Posted by AudiMaster1GER View Post
    This particular car runs 100cell cats and is street legal.
    AFR is up to 12.7 according to Phillipp (owner).
    The bangs you are product of NoLiftShift function.
    It is all in the tune.
