Results 1 to 18 of 18
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    HRE FF01 Tires - HELP!
    Ok....I'm about to pull the trigger on HRE Flowform FF01's....19x9.5 et45. Help me pick.....255 or 265 width (both would be 35/19). Pilot Super Sports of course. I'm lowered on Bilstein PSS10's. I can't decide on which tire width to go with and don't want to rub.
    I was all set on 265's as I like that look better but the shop said they usually do 255's on those.
    Not sure if this is also a factor to consider but Tirerack shows 5 different Pilot Super Sports all in 265/35/19 but they have different tread widths. Will that affect how much stretch there is and potential to rub?
    I was hoping to go 265's so there is less stretch but obviously don't want any rubbing issues.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I just ordered tires and wheels.
    VMR 803 19x9.5 et45 PSS 265 tires
    I went this route because i have a stock suspension and did not want any stretch.
    Wheels will be in Monday.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    PSS do run a little blocky and chunky if that makes sense if rubbing is a concern. Iv'e "heard some say a 255 PSS may run close to some manufactures 265 etc.
    Wait and see what the wheel/tire pro's say here
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Hit up jran. He's the guru for tire fitment
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    So I ordered this exact setup and did a TON of research. Running a 265 should result in almost no rub. However, it may result in a tiny amount of rub that will require removing a bolt in your fender liner in the front. I wanted to go 275, but did not want to have rubbing issues. From what I have read, 265 is a 95% solution. (My setup is due to arrive in 3-4 wks)
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Veteran Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens
    This is a 255 on a FF15 of the same size. Its not completely square but defiantly not what I would call stretched. I did this for 2 reasons one I didn't want to rub when lowered and it was a pretty decent price jump form 255 to 265.
    -Theo
    2018 S4,Florett Silver, Magma
    2014 Q5, Phantom Black Pearl, Chestnut, 2.0T,Moms Ride
    2015 S4, Daytona Gray, DSG,Gone
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic.
    Jul 20 2012
    Quote Originally Posted by yungcotter View Post
    Can you take a side profile shot for me that will show the amount of stretch? I'd really appreciate it. Looks great BTW!
    2013 S4
    Jun 09 2010
    Queens
    Quote Originally Posted by creativecody View Post
    Here you go I can go take a better one tomorrow
    Sent from my iPhone 6s using Tapatalk
    -Theo
    Jul 20 2012
    Would love to see a few more shots. Thanks!
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    I saw your PM, but I'll respond here. I'd lean more towards it not rubbing, and if it did rub, it would be really minor. I'd personally have no problem doing it, but I would go into it knowing there is a small chance of some rubbing.
    Now, some of that will depend on the tire you use. There are 4-5 different PSS's in that size, and as you mentioned in your PM, they run various widths. The Porsche and GM (TPC spec) tires run pretty wide; well, the Porsche spec runs really wide. If you stick with one of the MB specs, you should be OK. They are definitely more middle of the pack in terms of width. The MO is used on standard MB models, and MO1 is used on AMG versions (so, I'd maybe lean more towards it as it's only 0.1 inches wider than the MO version). All are similar XL/98Y rated tires with the same treadwear rating.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    265 all day
    Jan 04 2013
    Phoenix, az
    I will have mine Monday and can take pictures then for you.
    Jun 09 2010
    Queens
    Here you go.
    -Theo
    Veteran Member Three Rings zps123's Avatar
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    255 PSS on 9.5. PSS do have thicker sidewalls but they have a rounder profile. Good luck OP.
    2015 Audi SQ5
    Brilliant Black|BO|Black Nappa|B&O|NAV|KW HAS
    Past: '14 Audi S4 | '11 VW Tiguan
    Jul 20 2012
    Quote Originally Posted by cspcrx View Post
    Much appreciated!
    2013 S4
    Jul 20 2012
    Quote Originally Posted by jran76 View Post
    Awesome info.....thank you VERY much!
    2013 S4
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Here you go.
    Loving this
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Jul 20 2012
    Thanks everyone for your replies and pics and info! I'm going to go with the 265 width and as jran76 stated I'll make sure to get the MO1 spec PSS tire. I'll post back with pics when they are installed. Could be a few weeks.
    2013 S4
