Results 1 to 22 of 22
    Mar 30 2015
    Waukesha, WI
    06 2.0T No crank, no start
    This is on an 06 2.0T Quattro AT. I drove my car to a store without any issues. When I go to leave, it won't start. There is power to everything but the starter. I had somebody help me to jump it and nothing improved. The minimal research I was able to bring up was that it might be the starter relay.
    Lately before this happened it was having longer slower starts. Which led me to think it would be the battery. But it was very intermittent and didn't relate to whether it was a long it short drive.
    Oct 24 2015
    Perth, WA
    You may want to check the relays behind the cover under your steering.
    My respray thread
    Feb 15 2016
    Cambridge,Ontario
    If battery and ground connections are tight and you have. Good charged battery its likely the starter and less likely the ignition switch.
    Mar 30 2015
    Waukesha, WI
    I am ruling out the ignition switch because everything else with the switch is working just fine. There was an aftermarket remote start installed on it previous to me buying the car. When I return from my business trip, that is being removed promptly. Which relay is for the starter?
    Mar 24 2013
    Oakdale, CT
    I'd say it is most likely the starter itself. Have you been noticing it cranking slowly?
    -Adam
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Yeah probably the starter, just went through just about the exact same scenario myself haha
    2007 Porsche Cayman | 5MT
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    1) check your relays anyway and battery terminals just in case
    2) remove any aftermarket remote start kit before your car explodes
    3) get your starter rebuilt locally
    Problem solved.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    Rule of thumb for diagnosing a bad battery or bad starter...
    If you try to start the car and hear repetitive clicks.... it's the battery.
    If you try to start the car and you hear one click and nothing happens.... it's the starter.
    If you try to start the car and you hear nothing at all and and your interior lights work (kinda).... Could also be the starter, or the battery is completely dead. This scenario would need further diagnosing.
    Feb 15 2016
    Cambridge,Ontario
    There is no relay per se but the starter folenoid is bolted to the side of the starter so it's all coming out. Quite often the fine braided main starter wire fries.
    Mar 30 2015
    Waukesha, WI
    Who rebuilds starters anymore? haha. Where could I find the rebuild kit?
    I have ruled out the ign switch and the battery. The connections to the battery and the main ground are perfect. If there is no relay and it goes straight to the solenoid, I'll have to check for voltage.
    I'll get a better look at the starter when I finally have a tow truck bring it back to my house. It seems to be very difficult to get one out in the middle of nowhere.
    Mar 30 2015
    Waukesha, WI
    Does anybody have an ETM for this car or just the wiring diagram for the ignition and starter circuit? I need to do a lot more digging and make sure I get this remote starter out properly.
    Mar 30 2015
    Waukesha, WI
    The remote start is now removed. It still won't start. There has to be a relay for it. Does anybody know which one it is?
    Mar 30 2015
    Waukesha, WI
    Does anybody have wiring diagrams or troubleshooting trees to fit the conditions of my issue? I appreciate any help.
    Feb 15 2016
    Cambridge,Ontario
    just get your meter on the small wire to the starter solenoid. if you have 12 v while trying to crank its the starter/ batt/ connections .
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 24 2015
    Perth, WA
    scan the car mate otherwise you could chase this for a long time
    My respray thread
    Mar 30 2015
    Waukesha, WI
    After finally getting my manual in the mail, I was able to locate the mythical starter relay. Before all this, I did replace the starter because it did show the symptoms of a bad starter. I tested for power before and after the relay with the key in start, tested good. I then checked down at the starter and the constant B+ and control both showed with 12V. I pull the starter out and inspect it. The pin to the control was bent down and to the side, clearly not able to make the connection. Now to just wait for replacement to show up.
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    Quote Originally Posted by miA4 View Post
    wait did i just went through that? yeah i think i did and it was a bitch to replace lol where the hell is my DIY?
    Ivan
    Jul 17 2015
    miami
    Quote Originally Posted by dalmation53 View Post
    did it end up being the starter?
    Aug 20 2013
    Miami
    Yeah brotha. starter and battery both went at the same time. now is starting so nice. though that bolt behind the transmission was terrible to take off what a shitty design indeed.
    Ivan
    Mar 30 2015
    Waukesha, WI
    I used a through bolt ratchet similar to this one but older. The handle that I have is curved like a regular combo wrench. http://m.harborfreight.com/21-pc-sae...set-62305.html
    The only mistake I made was not checking for voltage before taking it apart the first time.
    Junior Member Two Rings fawaudi's Avatar
    Aug 05 2013
    Garden State
    I am having a similar case, it all started a month back, car would randomly not starting at all, but after couple turns of the key it would start up and car runs normal. All lights, radio, cluster, climate control, every thing seems fine, but no crank. This past Saturday morning it started up after I turn the key about 5 times, but today I parked my car at work and when I was leaving work it just won't start no matter how many time I turn the key. I ordered the ignition switch, being the fact that it is cheap enough and easiest fix to give a try, I hope it is the problem, but if anyone have any idea why, please share. Thanks
    Aug 22 2016
    oregon
    Quote Originally Posted by fawaudi View Post
    I'd check to see if the car is throwing any error codes.
    I bought this thing for $20 and it shows codes on your phone using the Android Torque Lite app.
    https://www.amazon.com/gp/product/B005NLQAHS/
    I figured out from that, and lots of googling, that it was likely the fuel pump relay. See more here: http://www.audizine.com/forum/showth...2#post11852912
