Results 1 to 23 of 23
    Veteran Member Three Rings rollaphillie's Avatar
    Jan 12 2009
    B6 A4
    PARTING OUT - 2004 Audi A4 B6 1.8T Quattro Sedan Brilliant Black/Black Leather
    Part out is done...
    How much for the coilovers
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    How much for the battery? And brake lines? Only need tears but if you rather sell as a set I guess I'd buy both. (rears only preferred)
    Jan 12 2009
    B6 A4
    Quote Originally Posted by hrd2pls View Post
    Quote Originally Posted by canadianA4B7 View Post
    PM Sent
    Veteran Member Three Rings kifac's Avatar
    Mar 24 2014
    Mississauga
    How much for the S4 brakes
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    As an aside, I've purchased from this seller. He's a great dude, and the parts are mint!
    Ryan, the rear stainless lines are gone. I asked for you in person.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Jan 12 2009
    B6 A4
    Quote Originally Posted by kifac View Post
    PM Sent.
    Quote Originally Posted by james12lucy View Post
    Thanks Lucy. Have you installed the stud kit on the B7 yet?
    And I still have a set of front and rear SS lines. They're still on the car though and different from the set of rears I had listed on here before. These ones are from USP Motorsports.
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by rollaphillie View Post
    PM Sent.
    You're welcome. Haven't done the stud kit yet. I did my Öhlins coilovers last week. I'll need some spacers for the studs and big brake kit. The engine bay and battery cover look great, and thanks for the ECU bolt. No more issues with moisture.
    You didn't have a Podi gauge, did you? I have the digital one and wanted one with a stepper motor. Also, tell me about your clutch and flywheel setup.
    I'll pick up the rear stainless lines for CanadianB7A4 (Ryan). Let me know what you want for them. Also, I'd be interested in the Koni shocks for the right price. I have the OEM suspension from my B7 you can have in the meantime. I know you don't want your car on jack stands. I can GIVE them too you whenever you'd like. I simply don't need them, even if I don't buy the Koni setup.
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    How are the fenders? I'd take the pair.
    Cheers,
    Claudio
    Jan 12 2009
    B6 A4
    Quote Originally Posted by Kabar View Post
    Seller seemes like a nice guy, but unfortunately im having problems with a purchase from him. I drove 5hrs to pick up his Koni SS coilovers, when I got there they were still partially on the car. No big problem, he gave me a good price on them so I helped take them off. When it came to the rear perches, they were seized and had to have oil on them for a couple hours to loosen them up. They are small enough to be easily mailed, and he promised me he would the next day. Two weeks later, still no perches..... What the hell dude?!
    Kabar, I left you a voicemail last week and didn't hear back from you. Sorry about this issue. Call me on my cell tomorrow, and check pm.
    Jul 04 2015
    Toronto Ontario
    I've dealt with Steve a few times, he's a great dude. You do realize people have other things in life going on outside of removing perches, correct? Things happen, and you likely should've kept this to PM.
    As an aside, I picked up rear stainless brake lines from Steve the other day, and he did it in two minutes. Would you to be late, he's a great seller.
    Jan 12 2009
    B6 A4
    Kabar sorry about the perches, I was not expecting them to be seized.
    All the parts for sale are now off the car as the car has been stripped.
    Anyone who's interested in parts can see feedback from others buyers at these links: CLICKY CLICK CLICK CLICK
    Jan 12 2009
    B6 A4
    Jan 12 2009
    B6 A4
    bump
    Apr 13 2009
    NS
    Steering rack and drivers window regulator ?
    Jan 15 2013
    00 TT 180
    Nl
    I purchased both the pressure and return power steering lines from Steve. Also got the clutch slave line from him. I would rate him a solid seller. The parts were quality, just as described, his communication was very good and the fees and shipping to Newfoundland were excellent. I would definitely purchase from him again. I feel that for a working person, doing a part out, everything about our transaction was timely. buy his parts without fear....
    Jan 12 2009
    B6 A4
    bump
    Jan 12 2009
    B6 A4
    bump
    Veteran Member Four Rings headshok2002's Avatar
    Jan 22 2005
    2010 VW Passat Highline wagon
    Sudbury, ON
    You still parting this? Been trying to get in contact with you via kijiji and text. Tried calling as well. Cash in hand and in Barrie if we can work a deal out. My phone number ends in 4229 if you check your texts. Cheers!
    Veteran Member Four Rings Cottonmouth's Avatar
    Jan 02 2009
    2016 Jeep Grand Cherokee Overland
    Burlington, Ontario
    Could you check the Injector Connector part number?
    The part number is 8E0973722
    If you have one I would be very interested.
    2006 S4 25quattro SE - #159 of 250
    2006 B7 A4 2.0T STAGE 2+ RIP
    Jan 12 2009
    B6 A4
    Part out is done.
    Jan 12 2009
    B6 A4
    It was just a heads up to potential buyers.... You should probably ensure the parts are off the car before you make the deal to buy them. I'm not assaulting this guys character, seems like a honest enough guy to me. After all he just offered to reimburse me for the perches. James12lucy are you for real? I made a deal to buy the whole set of coilovers. Without the perches they are useless to me. I'm having suspension problems and this was the fix for me, now I've been out a car for two weeks waiting... Things happen? Life gets busy? And I'm screwed I guess. You're really not helping your friends case man.
    Feb 10 2012
    parts
    Napanee, ON
    Battery had a dead cell!! Thanks for the help though James brought it to me unfortunately we cudnt use it.
    Do you have the power steering pump available?? Part number or anything close should work 8E0145153J.
    Hope you can help me out. I'm in a bind.
