I've searched and read articles on the web. I do not seem to be alone in my journey to bleed this slave. I've been trying to bleed the slave in my 2004 tt 225 for the past couple days. i replaced the clutch with a spec stage 2 with the new slave they include, i have replaced the clutch master cylinder as well. i have tried reverse bleeding, vacuum bleeding as well as normal bleeding. it starts out fine after first being bleed then not a few second later it goes back to the same, not able to shift. I've tried waiting 30 minutes then hitting with the pump method once, then wait 30 minutes and doing it again for 2 hours. still does great at first then goes back. I however did not soak and pump with fluid before install as i had no idea this was going to be so complicated. Anyone have any thing that will help me here? Please i am going nuts. just replaced the motor turbo clutch and flywheel but yet i cannot bleed this damn thing. hahaha been turning wrenches for years. last one i had this kind of problem with was on 350z bahaha and reversed bleeding always did the trick. now it won't work help please
