Really good condition overall but one of the top mounting tabs has a crack about 1/3 through it, should be a fairly easy fix with some epoxy or the sort. All other mounting tabs are intact. If you're handy you could probably come up with some other remedy However you can choose to run them as is, as I had no issue with them at all and they still sat perfectly level with the other headlight when shooting both beams against a wall at 15 feet away.
All bulbs are intact, as well as both ballasts needed to power the HID bulbs.
US part numbers with AFS: 8E0941029BD (Left headlight) and 8E0941030BD (Right headlight)
These are the top tier versons, as not all Bixenons come with the AFS feature:
"AFS stands for automatic leveling & focusing system, and is the feature where the projectors dynamically adjust and turn when your car turns to illuminate the road ahead of curves and maneuvers. Note: Auto-leveling and AFS are two different things. Auto-leveling is equipped on all xenon lights, and only controls up/down leveling. AFS is adaptive and goes left/right and is more sophisticated than simply auto-leveling, so do not assume these are the same thing."
SOLD (price drop)
