Results 1 to 16 of 16
    Jun 01 2016
    Louisville
    2001 Leather Seat - HELP!!!
    Hi all - new to the forum.
    I posted this in the "Ask a Detailer" section and thought I might post here too...
    I recently lucked into an awesome 2001 S4 Avant. It's pretty much perfect with only 110k miles on it. The leather on the seats are fantastic - at least they were until I went swimming this past Monday and evidently didn't dry off. Ran to the store left the sunroof open (and it was hot and bright out) and came back to basically what looks like "fried" spots on my leather.
    I've used mink oil, leather conditioner, and leather lotion at this point and nothing seems to work.
    Any help and guidance would be very much appreciated!
    Unfortunately I can't post attachments and clearly can't seem to copy/paste....I'll work on this ASAP.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Swimming in chlorine?
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by S4Cards View Post
    I did the same thing; the seats look like rhino butt. I figure if it bothers me that bad I can find a used set of seats for fairly cheap these days.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    did you try using like a soft bristle brush to work the stuff in, sounds stupid try a magic eraser, those things take way more off than you would expect. if its from chlorine though id say its probably not going to work.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Dec 30 2009
    Don't use anything abrasive.. magic eraser would just remove the finish from the nappa leather. You'll probably need to re-dye the leather, if you swam in chlorine, is what I was getting at.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    Quote Originally Posted by Timtheguru View Post
    use magic eraser one every seat i own...never had a problem.
    White 07 Q7
    Dec 30 2009
    Quote Originally Posted by audacity View Post
    Interesting. :) Using it on Black Nappa leather? What kind of damage does it repair?
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Jul 07 2009
    Alberta, Canada
    I wouldn't use the magic eraser personally. It's designed to act as an abrasive.
    Try a mild all purpose cleaner and microfiber or horse hair brush.
    Dec 30 2009
    My understanding as well.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    won't repair damage. but will clean whatever is off the surface with ease. that being said, the surface. have cleaned grease out of alcantara with it, if that stupid fabric can handle it pretty sure the leather can.
    White 07 Q7
    Dec 30 2009
    Ah, yeah I'd use it on Alcantara not leather. The Alcantara is a faux suede that would be more durable than the leather finish.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Nov 05 2009
    Denver
    Guys, it's not dirty or discolored, the leather got super dry from being moist and then quickly evaporating in hot ass direct sunlight. He needs a moisturizer but it's so labor intensive with marginal results.
    If anyone has a solution that will actually doc the dryness that would be awesome. And don't say KY
    Veteran Member Three Rings s4andtls's Avatar
    Jul 14 2009
    Ma.
    Car leather seats are clear coated. I would use simple green first to clean everything (use bristled brush) . Then conditioner, like Meguiar's. For expert advice see my post above.
    605.2 Brad tuning now
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Quote Originally Posted by Zba View Post
    This stuff works for dry leather---BAG BALM....Amazon sells it in 8oz containers...You'll need to rub this stuff into the leather..massage the hell out of it, there is no way around that fact...it will take some time but will work...I got this tip from an acquaintance whose business is automobile detailing..It WORKS.
    PS- I use this on the leather portions of my seats once a year
    PSS- It has a bit of a medicinal aroma but that clears quickly...You'll also have real soft hands when done :)
    Nov 05 2009
    Denver
    Quote Originally Posted by LJS View Post
    Interesting. I'll have to give it a whirl thanks!
