Results 1 to 4 of 4
    Jun 03 2016
    Dallas
    Unhappy Difference between CAEB and CAED??
    Hello everyone, first post! and may be a tough one.
    Got 2012 A4 S-Line manual, CAEB engine code. 5 months out of warranty cylinder #3 is not holding compression dealer will only do at cost replacement which is around 8k. Decided to do the swap at my buddies shop, looking for an engine now.
    Found a CAED 2.0t that came out of 2014 A4 S-Line manual (with plastic intake manifold, just like mine). I read through the "How to: Audi A4 B8 2.0 TFSI CAEB SWAP TO CPMA / CPMB" (http://lovetodiyandmore.com/page8.php?category=14) which was a great resource but the question is:
    Will the CAED engine swap into my 2012 A4?? Im guessing if the CAEB to CPMA is possible then the CAEB to CAED will be as well?
    Does anyone know what are the primary differences between the CAEB and CAED engines? Aparently the CAED is in some A6s as well but could not find much info on how the two differ or whether the swap has ever been done before.
    Also are there any differences in transmission mount patterns within B8 and B8.5, or are they universal for most 2.0t engines?
    Thanks!!!
    Veteran Member Three Rings mr_milo's Avatar
    Oct 18 2013
    SF Bay Area, CA
    I have been wondering this for some time now... basically two + years since I bought my car.
    Here is the little I know:
    1. The reason the 2014 engine you found is a CAED is because it came out of a 6 speed manual transmission car. If it was an automatic it would have been a CPMA / CPMB.
    2. The CAED is NOT E85 compliant.
    I know that's not much but hope it helps.
    2014 A4 P+ 2.0TQMS
    2011 BMW 328i Convertible 6 Spd Manual - SOLD
    1999.5 A4 1.8TQMS - SOLD
    1986 4000CS Quattro 5 Spd Manual - SOLD
    Save the Manuals!
    Jun 03 2016
    Dallas
    Quote Originally Posted by mr_milo View Post
    Thanks Mr. Milo. That is what I was guessing as well. Gonna go ahead and order it. If the only difference to CPMA/CPMB is the tranny then the swap is doable. Will try and document the swap and post the results.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    Quote Originally Posted by vongsuev View Post
    Updates?
    I'm in a similar situation.
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
