Have you seen this:
https://jhmotorsports.com/shop/catal..._62_64_234_301
As we stated above, our JHM ECU Tuning you will give you noticeable improvements in the performance of your 3.0L. However, if you add our JHM 2.5" Stainless Steel Downpipes ON TOP of the ECU tuning, it will completely transform the power band of your car. If you are looking to unlock the potential of you 3.0L V6, these 2.5" downpipes are the key. Check them out in the Engine and Performance Section. They are an absolute MUST for anyone looking to get more power out of their car. Our extensive research proved this point time and time again. When we put our 2.5" downpipes on a stock car, the car was impressive and the increased airflow of the downpipes definitely made the car seem a bit more "peppy". However, when we put the downpipes on a car with a JHM B6-A4 3.0L V6 ECU Tune on it, the result was amazing. The combination of the increased airflow from the downpipes and the ability of the JHM ECU Tuning to take advantage of that increased airflow completely transformed the power band of the car. The gains in low-end torque were good but the most impressive power increase can be found in the top-end of the RPM range. With the motor breathing more freely and the addition of our ECU Tuning, the 3.0L just keeps accelerating up top!
