Results 1 to 8 of 8
    Aug 28 2013
    belleville nj
    Just did a motor swap need help
    So recently my motor blew on my 09 and i just swapped it out with a 2010 motor, everything is installed correctly , car cranks but doesn't fire, any ideas?
    @carbon_cleaning
    May 02 2011
    '15 A6 3.0t, '14 GMC Denali Duramax, '12 F150 EcoBeast
    Casper, Wyoming
    Don't you have to reregister all the engine modules with the security setup with a vagcom or am I smoking crack?
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Start simple, check for fuel and spark.
    Jun 26 2009
    Bremerton WA
    Does the tach register the engine cranking? Do you have an OBD scanner?
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    Crap! Sorry to hear this Vin! Hope all goes well!. Thought I may have spotted you on Intersection of Jerolemon & Franklin today.
    Oz
    2013 Scuba Blue A4 Premium
    EuroCode / APR / H&R / Bilstein / VagCom / AWE / NGK / 034 / GFB / HRE / Valentine1 HW / CR15 / Black Viton Injector Seals / Fluidamper / Ko4 #00Negative
    Aug 28 2013
    belleville nj
    Its getting fuel just no spark but the tach does show the rpm moving for a crank
    @carbon_cleaning
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The immobilizer or engine ECU module does not "know" or "care" if you replaced the engine mechanical components....
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    @S4'ed Asking because I'd genuinely like to know but from the keybob to the ingition to the ecu to the engine where is the protection/pairing actually important?
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
