Results 1 to 28 of 28
Thread: RIP Audi K03S
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    RIP Audi K03S
    Hey Guys,
    Turbo is officially making the dentist drill sound. I guess it took going up a steep grade at 75mph to take it out. I soon as I pulled into the gas station I heard a weird noise almost like knock then it turned it a dentist drill sound, quite fascinating actually lol. One question is it ok to drive the car like this for a while? Secondly, get a rebuilt K03s or Frankenturbo F21? I think I know what the answer is....
    Nathan
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    No telling how long it will lat, but my turbo is making dentist drill like noises and I have no immediate plans of swapping it out.
    Either get FT or I have always been curious about the Mahle turbo on Rock Auto for $570. When I get around to it, I think I will go the FT route.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Apr 26 2010
    North Jersey
    Quote Originally Posted by redline380 View Post
    Ok as long as there isn't any long term effects. I like keeping my car in tip top shape.
    Established Member Two Rings pgiuliano98's Avatar
    Jun 22 2015
    Livonia, New York
    My turbo blew about 3 weeks ago and I don't plan on changing it for a bit... As far as I know so far there haven't been any bad side effects.
    Also picked up a used k03 for $60 shipped in the classifieds on here
    Apr 26 2010
    North Jersey
    Quote Originally Posted by pgiuliano98 View Post
    Yeah, the car still accelerates normal but it still makes the dentist drill noise. When it gets warmer it quiets down a bit. It's very loud when the oil is cold. It doesn't smoke either so possibly it could of been a partial failure.
    Jun 22 2015
    Livonia, New York
    I'm also on a tune for 17psi and the noise doesn't start until around 10-11 so mine is probably a partial blow as well.
    Apr 26 2010
    North Jersey
    Yep! Oh well I'm going to drive it like a grandma. I don't want to make it worse. Atleast the car still has power.
    Sep 12 2008
    South Central PA
    If the car still has power the turbo isn't blown. If your blow your turbo and drive your car the bearings of the turbo will start breaking apart and going into your oil pan as the shaft is slapping around in there. Not to mention that the compressor and exhaust wheels could blow apart, sucking a bunch of metal into the engine doesn't sound rad.
    Look for a vacuum/boost leak before deciding the turbo is done.
    Story time
    I thought I blew the K03 on my B6, ordered a eliminator kit because why not upgrade? When removing the stock turbo I found a big tear in the turbo inlet pipe that was causing the dentist drill noise, and making it run shitty because the MAF sensor readings were fucked. I spent $3,400 because I jumped to conclusions. And it was not worth it because I tore it all out and went full frame like 8 months later.
    A little diagnostic time is always worth it.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Apr 26 2010
    North Jersey
    Quote Originally Posted by Dan[FN]6262 View Post
    Story time
    Wow! Thank you for this story. I actually have a silicon TIP waiting to get installed. I will check the rubber TIP and see if there is anything broken. It whines like supercharger (roots blower) like muscle car but it's not loud like it was last night.
    Sep 12 2008
    South Central PA
    Yeah man, a K03 is a noisy little fvcker. Especially if it doesn't have to draw air through an airbox designed specifically to keep it as quiet as possible lol.
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    What is a K03s ??
    SOLD the GOINHAM A4 ---> GT2860 Project
    Jun 22 2015
    Livonia, New York
    RIP Audi K03S
    The k03s (sport) has a compressor housing of 39.5ml instead of 37ml on the k03. The k03s also came stock on 01 models.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    There's no such thing as a k03 sport. It is a revised turbo, that is it. Nothing sporty about it.
    Most people do not know this, but the turbo was revised for the 2000 MY and it was the same through the B6 chassis. Same exact turbo, same PN. Yes, that is correct. An ATW with 150hp has the same turbo from the factory as any 01 or B6 with 170hp.
    2000 S4- Working?
    Nov 17 2011
    Fredneck Maryland
    hmm thought this was a myth, thanks for the answer I was somewhat trolling.
    Jun 22 2015
    Livonia, New York
    RIP Audi K03S
    I was wrong... Look at redlines response^
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I will say that it looks like there was another revision in 2007, which is obviously after b6's ran there course. The replacement is an "n' model in stead of the "j" model but applies to all 1.8ts/
    2000 S4- Working?
    Apr 26 2010
    North Jersey
    So your telling me the turbocharger is exactly the same and through factory stock tuning is pushing more PSI then yester years audi...hmmm....Well when I do my oil change I am going to inspect the piping, if everything doesn't check out I will put the turbo post results.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by SN95Audi87 View Post
    Bingo. AWM and AMB used revised mapping and additional boost to get the extra 20hp. Stock pressure on ATW is 7psi, on AWM/AMB it is 11psi
    2000 S4- Working?
    Apr 26 2010
    North Jersey
    Man someone should post a sticky about the 01 Models saying that it is a myth lol.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    It is more fun watching noobs get all worked up about how awesome their ko3s is compared to the "stock" turbo. There is technically a size difference between a stock 1999 and a stock 2000-2006 turbo, but the difference is de minimis and has a negligible effect, if any whatsoever, on performance.
    2000 S4- Working?
    Jun 22 2015
    Livonia, New York
    Very glad I didn't buy a ko3s for $200 more than I got my ko3 for now lol
    Apr 26 2010
    North Jersey
    And the plot thickens. Well my car is virgin with all oem hardware so we can get to bottom of this soon haha.
    Sep 12 2008
    South Central PA
    I had a AEB K03 and a AMB K03 laying the garage for a while.
    The only differences that you could see with the naked eye are that the compressor fins appeared to be arranged slightly ... closer together (maybe the secondary fins weren't quite as short, like were closer to the shaft nut?) on the AMB vs the AEB. The AEB compressor wheel looked more similar to a K04 wheel, this is naked eye of course.
    Who knows, that was like 6 years ago now lol maybe one was more dirty than the other and it just looked that way while actually being identical. I'll have to dig through my pile of parts and see if I can find them, I'm curious now lol
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Feb 27 2011
    Winnipeg
    thats the only difference is compressor wheel and possibly slight exhaust housing differences, I'd have to go check my pile of turbo cores, AEB had the k03-005 and AWM, ATW and AMB had a k03-029 almost the same damn turbo although the later turbo is cheaper than the AEB one so I don't know why anyone would put the older turbo on their car. The whole k03s seems to come from people hanging out on vwpoortex talking with the transverse crowd.
    Also if it's howling at higher boost levels then see attached pic, my b5 s4 driverside k03 started making drill noises over 10psi and that's what I found.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by seanf86 View Post
    Yup!
    And I believe the revisions were due to cracking exhaust housing, or at least that was part of the impetus to change. Remember that, when everyone was cracking housing? Been a while since we a thread like that.
    2000 S4- Working?
    Feb 27 2011
    Winnipeg
    Yup!
    my K03-029 in my B6 got heat distorted and ground down my turbine wheel resulting in me having to buy a complete new turbo as well as my wifes B6 altho those ULEV cats are notorious for plugging so thats probably what happened.
    Apr 26 2010
    North Jersey
    I wouldn't be surprised if my turbo looks like yours in your picture. My car has 175k on the clock, I really believe heat took it out. Definitely a testament to Amsoil though, I've been running there lubricants for years and thats what probably made the turbo last so long. If it wasn't for my failing catback, the turbo probably could of went to 200k. I recently upgraded the whole exhaust and intake pipe so that with me beating on it for the last few months just broke the camels back.
    Nov 17 2011
    Fredneck Maryland
    I was 99% sure you where lol I am bored at work
    [IMG][/IMG]
