Only a company as experienced with performance innovations as Neuspeed could develop a product so deeply effective and simple to operate.
The Power Module allows your S3 ECU to safely increase boost levels by a precise amount without changing factory ECU programming, communication or safety protocols.
Net up to 35-40+ HP with 5-7 PSI increases, all controlled via the simple two-position switch.
The unit plugs directly at the Boost and MAP sensor connector locations - installation and complete removal can be completed in minutes.
Will not void manufacture's warranty!
Your secret is safe with us.
Jason
