Results 1 to 4 of 4
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    VW to Audi bolts/nuts interchangeable?
    So in the excitement of buying coilovers I forgot to order the hardware. It's Thursday and already set up Saturday as my install date at my cousin's shop. Being impatient I decided to bite the bullet and buy all necessary one time use / tty bolts and nuts at the dealership. The catch is I went to a VW dealership (if I'm going to do the install perfectly I have to half ass somewhere lol) I basically ordered the bolts for a mk7 gti/golfR do you think I will run into compatibility problems? It's the same platform.
    Sent from my SM-N910P using Audizine mobile app
    Instagram: TonyConQuattro
    Feb 13 2015
    VA
    They'll be the same
    2015 S3 - Revo Tuned
    2016 SQ5
    2008 F350 - Pistons/Cam/Studded/Deleted/Single Turbo
    2010 GT500 - Twin Turbo
    Feb 21 2016
    Quote Originally Posted by S3Danny View Post
    They'll be the same
    Okay, good. One last question, half of those bolts I couldn't find torque specs for..is it safe to trust what Bilstein says per bolt size or is there a thread in the 8v section that I might of missed and should refer to instead?
    Feb 13 2015
    VA
    Unless it's a bolt where clearance is critical, torque value isn't all that important. If the bolt goes through a bushing then you'll at least want to be close.
    2016 SQ5
