Results 1 to 3 of 3
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: RS4 Jack Pad Kit For Your Audi B6/B7 S4
    Prevent bent frame rail pinch welds and future corrosion complications with a set of RS4 jack pads. No more metal-to-metal contact!
    These Genuine VW/Audi pads install snugly over the frame rails in the OEM jacking point locations, providing a flat surface from which you can confidently lift your car.
    *This kit does require a slight modification to the frame rail to permanently mount the jack pads. All nutserts (rivnuts) and mounting hardware are included.
    Adaptive longevity.
    Fits:
    Audi B6/B7 A4/S4 2002-2008
    Jason
    Senior Member Two Rings M0ve0ver's Avatar
    Jul 18 2010
    Ft. Hood, Texas
    I have some, awesome quality.
    One word of note... if your car is lowered and you install these, make sure you have a low profile jack... it reduces clearance by about 1.5" or so.
    05 B6 S4: JHM 93 Tune, Trex DP, JHM 2.5" CB, JHM LWCP, Apikol snub, Bilstein PSS9, 034 Adj Control Arms, 034 Rear Sway + Endlinks, 034 front Endlinks, Team Dynamics Pro Race 1.2's, 034 wheel studs, 034 Strut Bushings, 034 Lower Control Arms, tyrolsport caliper bushings, ECS braided brake lines, Hawk HPS pads, Evo skid plate
    13 8P A3 TDI: Malone Stage 3 Tune, CR170 turbo, Rawtek DP, Malone DSG tune, Darkside Race Pipe/EGR delete, CP3 fuel pump, Panzer skid plate
    Oct 02 2006
    Wadsworth,OH
    Appreciate the feedback! Definitely a good word of advice for those that are lowered
    Jason
