Originally Posted by
customa4
Sounds like a leak near the LDP. This should help.
Click
Also, on the CVT I believe the fuel pump is in the trunk.
Yes edited it, thanks for the tip. I blamed it to my bad memory lol.
I have no idea where the LDP and evap canister located on a FWD car?
AudiTechS4
ldp is on the other side. pull your rear seat out and pull the black cap off (3 gold Phillips screws) and see if your fuel pump cap is wet
My pump is located in the rear right trunk. In my theory, if the pump is leaking, I can smell it inside the car right?
CyberPMG
There is an evap filter that exists on the other side of the rear passenger wheel well. Paper filter could be clogged especially if you're getting any secondary air "incorrect air flow" codes. I'm trying to hunt down a similar smell even after replacing the fuel filter and fuel pump. Not sure if that filer could be causing the issue.
The other side(driver/left side) of the rear wheel is smell-free too, the smell only found in right rear wheel. And I don't have any code. But I'll try to check it from this way. Thank you!
f0reignfeatures
What model year is your car? I know when I replaced the fuel pump on my 2002 B6 (3.0) the replacement (VDO - OEM manufacturer) had an extra nozzle on it that had to be capped off with a special coupling piece from Audi. It was available at the dealership for about $12. Might be something to look into, good luck!
Mine is 2004 euro spec. I'll definitely check the pump. Thank you sir!
