Results 1 to 6 of 6
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Do you flush your Power Steering Fluid every two years?
    Do you flush your Power Steering Fluid every two years? Or will that only introduce more problems down the road?
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    ive only topped mine up since the rack got rebuilt about 6 years ago
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Aug 04 2009
    Glen Ellyn, IL
    I flushed mine when I installed my new rack but I have to assume the fluid previously was 13 years old.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Dec 27 2014
    2013 Audi Q5 3.0T
    My fluid is looking really old now. I never flushed my fluid and its been over two years now. I'm pretty sure its already crossed the maintenance interval. The mantra usually is to change only if its a legitimate problem, but flushing fluid is preventive maintenance. I'm sure its a good idea to do this after I'm done with my other task (replacing suspension components), right?
    I hope new clean fluid doesn't mean new fluid spewing near the timing belt area, lol
    There's an old saying, that when replacing fluid, it makes it more susceptible for leaks to start spewing.
    Current:
    70,xxx Miles
    182,xxx Miles
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    I replace mine annually because it seems like I either do an engine pull or core support removal annually for some audi reason or another
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    Just leave a clamp slightly loose on the power steering cooler return line and your system will bleed itself over time, particularly in the winter, then just add fluid every few weeks
    Just kidding. Or am I
