Results 1 to 8 of 8
    Senior Member Two Rings bgeorge520's Avatar
    Oct 04 2013
    New Jersey
    01314 Engine Code--2010 S6 Wont Start
    Hey guys, my 2010 S6 wont start. I tried hard wiring my radar detector and when I tried starting the car after installation the car cranked but didnt start. I disconnected the radar detector and tried again and it cranked. I tried again and the car stopped cranking. Hooked my VAG-COM Cable up to it and got these codes:
    Thursday,02,June,2016,07:55:27:55829
    VCDS Version: Release 15.7.4 (x64) Running on Windows 7 x64
    www.Ross-Tech.com
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Control Module Part Number: 4F0 910 801 D HW: 4F0 907 801 B
    Component and/or Version: EPB CEFC0090 H05 0090
    Software Coding: 0008022
    Work Shop Code: WSC 02145 785 00200
    VCID: 214934E8F813FF3651-8074
    3 Faults Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 4
    Fault Frequency: 32
    Reset counter: 144
    Mileage: 105704 km
    Time Indication: 0
    Date: 2016.06.01
    Time: 18:26:37
    Freeze Frame:
    Voltage: 11.39 V
    Count: 241
    01315 - Transmission Control Module
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 32
    Reset counter: 144
    Mileage: 105704 km
    Time Indication: 0
    Date: 2016.06.01
    Time: 18:26:37
    Freeze Frame:
    Voltage: 11.39 V
    Count: 243
    01316 - ABS Control Module
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 32
    Reset counter: 144
    Mileage: 105704 km
    Time Indication: 0
    Date: 2016.06.01
    Time: 18:26:37
    Freeze Frame:
    Voltage: 11.39 V
    Count: 242
    I checked all of the fuses, disconnected the battery, the ecu ETC but I am willing to go through the whole process again if anyone has any suggestions that will helo. The car has never had any starting issues before and the code will not clear. Any help would be greatly appreciated
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Go pic yourself up a battery. 11.3 volts isn't gonna start a V10
    Oct 04 2013
    New Jersey
    Will I have to get it towed to the dealership to have it coded?
    Oct 04 2013
    New Jersey
    Got a battery from the Audi Dealership installed it. Still getting the same no communication codes with no ECU communication. Battery volatge is still the same. Tried going in to the battery regulation to code the new battery but cant get in because theres no ECU communication. Any suggestions would be helpful. Thanks
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    I know you have most likely accomplished this, but I'll mention anyway because your situation sucks:: have you rebooted your pc running the vag-com? I've run into a similar issue where I could not communicate with some or all modules on car and a reboot fixed it. Otherwise, I wish you luck on this one.
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by Nizmo View Post
    Voltage has almost nothing to do with cranking ability on any starter on an automobile, in the way you are implying. It's a 12v system and a 12v battery. AMPERAGE available from the battery is what would be of concern with regard to 'starting a V10.' That being said, if the voltage is out of spec, who knows what the modules will or won't do. 11.4v is most likely just fine.
    Feb 21 2012
    Aurora, CO
    Quote Originally Posted by bgeorge520 View Post
    Your battery voltage is fine, and it was also fine on the old battery.
    What specifically were you 'hard wiring' the radar detector to? Give us a detailed description of how you did this and from where you were getting power.
    Oct 09 2015
    Boston
    Quote Originally Posted by SlickMachine View Post
    Interesting, when I took my ASE Cert. the question was correct starting voltage. Answer was 12.2 this "customer" has 11.6
    I as well have an S6, and it takes lots of juice.
    Got a battery from the Audi Dealership installed it. Still getting the same no communication codes with no ECU communication. Battery voltage is still the same. Tried going in to the battery regulation to code the new battery but cant get in because theres no ECU communication. Any suggestions would be helpful. Thanks
    Now that battery is new and correct, lets start looking into fuses. Seeing the car was running before the radar.
    -Check All Fuses
    -If installed am "add-a-fuse" you possibly have disabled a system by adding the radar to it.
    Some forewarning before your frustration on this runs high. There are 2 ECU's. 1 for each cylinder head. Chances of you popping 2 ecus are slim to none on a radar install, not enough amps to blow those fuses.
    -My bet is on improper installation of the radar and grounding out an active system. (No offense and no disrespect intended.)
