Results 1 to 8 of 8
    Orange County, CA
    Intermittent Coolant Gauge issue...
    The gauge recently started showing nothing but it starts showing after driving for 30-45mins sometimes...
    Without finding an a thread or great info on google-
    VCDS shows me this of the G2 if others have direction (and pictures) with this issue-
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    Thanks in advance-
    B5 Parts For Sale
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Replace cts should fix it.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Agreed ^
    With VCDS you can separately enter the Engine and Instrument Cluster modules, and view their respective coolant temperature values. The CTS sensor has two separate sensors internally, and it's possible only one has gone bad.
    2001 Corvette (C5) Z06
    Junior Member Two Rings bern_10's Avatar
    Feb 05 2012
    2017 Tacoma
    Spokane, WA
    Don't get the brand URO; mine lasted less than a year.
    Laser Red 2001 a4 1.8TQM, 240k miles, b6 wheels, Giac chip, Carbonio intake, ST suspension, ECS brake lines, RAI test pipe, mud flaps
    Registered User Four Rings FCPEuro's Avatar
    Jul 30 2009
    Milford, CT
    Agreed with the above, make sure you are also get the o-ring for the temp sensor (part number 059919501A) and the clip that holds it to the flange. These temp sensors are dual purpose as aforementioned, dual control switch, and auxiliary fan switch. Original 1.8t units were black, new ones will be green 4 pin. Common replacement item.
    Senior Member Two Rings RagtagXMASTER's Avatar
    Jul 15 2012
    2002 dodge RAM 1500
    Boston MA
    I got a mahle good quality. I have changed them all the time my last one was a uro. It failed after 6 months. My mahle so far is good for a year. But i no longer drive the car
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Thought I had replied to this. I agree with avoiding URO brand, mine failed within 15k.
    Sent from my LG-H815 using Tapatalk
    Orange County, CA
    Very good responses, thanks a lot everyone. This is what I was looking for before going after it.
    B5 Parts For Sale
