Results 1 to 27 of 27
    Established Member Two Rings mdeneso's Avatar
    Sep 11 2014
    B8 S4 15 T-Reg 05 ZX10R
    P0087 Low fuel pressure Help!
    I started my car after work and it took a few seconds longer to start than normal, then it stuttered for a second. After that initial start up all was fine. I drove the 25 miles back to my house and didn't notice any difference in drivability or power. When I got home I noticed a CEL and started the car again, had the same slow start. Scanned the car and got a P0087 Fuel Rail/System pressure too low.
    I am thinking the problem is the lpfp, mainly from the slow start symptom. Any other ideas on what it may be? I'm taking in to the dealer in the morning, will follow up with more info. Thanks
    Nov 20 2014
    New York
    I've had the same problem but I'm running e85 mix and I have a new lpfp
    Sep 11 2014
    Quote Originally Posted by sonic32 View Post
    I am not running any e85, but did the lpfp fix the problem or is it still occurring with a new pump? I'm a little confused.
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    I don't recall the code but I just had similar problem and it was the hpfp.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Same here, to much e85..
    You might have gotten bad fuel, burn that tank and refuel and clear the code.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    I have had this code when running E85 and it was my HPFP. The Auto-Tech upgrade took two tries before it was right. Looks like the first time around something was off on the machining of the piston.
    Oct 11 2012
    San Martin CA
    when I got that code on my 2011 A3, the car also went into limp mode. The HPFP had disintegrated itself...luckily with no other damage. The car was still driveable using the LPFP only, but no boost and felt like 50hp. Doesn't sound like your situation is as bad.
    Sep 11 2014
    Started slow again this morning, no power issues on the way to the dealer. It feels fine throughout the rpm range, only symptom right now is the slow start. Should hear back from the dealer soon. I will update this post with the solution in case anyone else has the same issue.
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    That code is not a LPFP code. LPFP would be P310B "Fuel pressure out of spec - low pressure fuel system." Your code is likely related to your HPFP and it needs replacing.
    Sep 11 2014
    Quote Originally Posted by LittleDozer View Post
    Ok, hopefully hear back from the dealer soon. Do you have an idea on what the replacement time is for that? I thought I read that the charger has to be removed.
    Jan 21 2014
    Quote Originally Posted by mdeneso View Post
    1 hour tops. You can see it in front and upper area of engine. Once the car is depressurized (which is super easy to do) it's just a few hoses/clamps/bolts that need to be pulled.
    Jun 17 2009
    I believe the book price on the hpfp replacement is around $1100
    Jan 21 2014
    Quote Originally Posted by esimp2k View Post
    If someone pays this they got effed. In no world would it cost that much. Most anyone should pay is $500 if that.
    Jun 17 2009
    I didn't say it was worth it. I said I think that's what the book value is as OP said it was at a dealer.
    Nov 20 2014
    New York
    Even with the new lpfp I still get slow starts but like I said mine i bet is from e85. Doesn't matter how much I run anymore, even if I drop the mixture still slow start, I think I already messed up the hpfp. I'll grab an auto tech rebuild kit and be ready for full e85
    Sep 11 2014
    So the dealer wants to "start" by replacing both pressure sensors and is going to charge $1200 for that. So I will probably just pick it up and try and figure it out myself.
    Sep 11 2014
    For an update in case anyone runs into a similar problem in the future, they replaced the high and low pressure sensors and it seems to have solved my problem. I drove it for about 20 miles today and it seems all is well now. The sensors were sending wrong signals to the pumps causing incorrect pressure values. The charger had to be removed to gain access to the high sensor.
    Jan 21 2014
    Do you have a part number for the high sensor? I thought the only sensor was attached to the HPFP but there's also one on the rail under the charger?
    Sep 11 2014
    I can try and dig out the work order from the dealer to see if they listed a part number.
    Oct 20 2015
    Norristown
    Hi LittleDozer - How do you depressurize the the system? I need to change the HPFP on my B8 S4 and I'm just waiting for the HPFP to come in. But I cannot find a good description anywhere on depressurizing the system. However, I found steps for the rest of the process. Any help would be greatly appreciated!
    Jan 21 2014
    Quote Originally Posted by endree View Post
    You need to pull the fuse on the driver side fuse box. It's a panel between the drivers dash and the door. I think the fuse has a #5 on it. The owners manual has an area that tells you.
    After the fuse is pulled just run the car until it dies.
    Recently I've just been doing it the ratchet way and twist the metal lug that holds the rail to the HPFP. If you do it just enough in a well ventilated area it'll slowly blow off the pressure.
    Jan 26 2015
    2017 XC90, a workbench
    CO
    This. Done it myself.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Oct 20 2015
    Norristown
    Thumbs up
    Thank you very much for the tips! I was going to twist the metal lug, but I was worried it is so pressurized that I would break something. So I guess I will try the fuse method as I was going to remove that fuse first anyway. Is it true that you you need a 6mm hex bit (flat end) to get the 2 bolts off that hold the HPFP in place? Thanks again for your help. I am having issues with fuel pressure bleeding off as the car sits. It isn't enough to set off a CEL, but it's enough to make the car take longer than normal to start than stumble for a second, after the car sits for several hours. After that, it runs fine. I am really hoping it isn't that sensor/valve under the blower... Taking a gamble by just changing the HPFP. I really don't feel like removing the blower, especially as I can't find a decent DIY on that. Anyway, I hope to do a write up after I fix the problem. Crossing fingers.
    Thanks again!
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    Thanks again!
    Any follow up to this? I just got this code and only this code. But I've already upgraded to the auto tech hpfp to run full e85 fuel. I have a feeling it might be that. However there's another thread where someone mentioned they turned on the AC when it just got hot out. That just happened right now before I got the cel... rather interesting... torque app doesn't mention anything about AC though.
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Quote Originally Posted by jachien View Post
    second this also got this code but disappeared after getting it scanned via auto zone and has not come back since. Car drives fine
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Jan 21 2014
    P310B is related to the low pressure ( in tank) fuel pump, not the high pressure pump. An Autotech upgrade won't stop this code from popping up.
    Nov 12 2012
    Cerritos CA
    Honestly I really didn't think this code is hpfp related but many posts seem to believe so. I actually have the p310b committed to memory since I haven't upgraded to the flex fuel pump yet that I know you and a couple others have done so already... I'm just waiting for that code to pop up eventually.
    Torque doesn't actually say anything about fuel pressure. The app says drivetrain fault and that's it really. I know sometimes the code that pops up might be manufacturer specific instead of the general obd2 codes torque is based off of. But anyway... car runs fine it seems. Actually I did a wot 3rd and 4th gear pull just now and didn't get any sputtering. Lol. This car is like a woman sometimes...
