Thank you all for your input guys.
Noticed during installation at the rear that only one slider bolt needs to be removed to pull the calliper off and replace the rotor&pads.
Ferodo pads are beaded in properly and holy hell do these BITE!
Originally Posted by
Seattle squash
Looking good, what was the reason for the combo? I likely go the jhm 380's next in the front. Also, anyone sell the up sized rears w/ bracket/adapter? As far as I recall most of the ones I see remain the stock 324 or something like that. And yes, I know the rears suffice as is but upgrading is my hobby! :)
Hey man! I went with AP because I intend to track the car a bit and importing the JHM fronts or getting the OEM fronts was both more expensive and they aren't good track quality as far as I researched the interwebs.
For the rears it was a price based decision and I wanted floating rears, so I went with the JHM rears as I was buying the Hotchkis rear sway-bar at the same time.
Note on the stiffer rear sway-bar: DAMMIT it's a new car!
For the up-sized rear rotors the only ones I know about are the ones that come with the Stoptech Rear Big Brake Kit ST-40 at a size of 355x32. For comparison the rears in the AP big brake kit are still the same dimension.
