Results 1 to 4 of 4
Thread: Leveling Sensor
    Jan 14 2016
    NC
    Leveling Sensor
    So I recently had service done on my audi. New cylinder head, new timing belt kit etc. After I got it done the leveling sensor/ dynamic range control icon came on. The headlights point downward and won't level up. Anyone had this problem before and/or know how to fix it?
    Sent from my SM-G900V using Tapatalk
    Senior Member Three Rings fyremanpat's Avatar
    Jun 03 2014
    2011 4Runner
    Either one of the three sensors are unplugged or one of them has crapped out. VCDS will tell you exactly whats wrong. Scan it and go from there.
    04 A4 B6, VMR 710s, SB stage 2 daily, GTRS, 550cc inj, Motoza, Billy Boat stealth exhaust, test pipe, Carbonio intake, R1 Diverter, Black FMIC, B5 S4 front brakes, Meyle HD front end, Solo Werks coilovers, Ecodes
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    They may of also turned the power to the car on with the headlight out or unplugged.. Its one of those errors you have to go in and clear with vag-com.
    2013 Solar Orange S4
    6MT | APR stage 2+ Ultra | Eurocode Headers | APR CPS | Meisterwerk clutch | Milltek Exhaust (resonated) | KW V3 coilovers | HRE FF01 | Stoptech trophy BBK | Alu Kreuz | Eurocode Sway / Endlinks / Trans & Dif mount | LYKT Control arms | E-Codes | Eurocode Short Shifter | P3 Gauge | Vinyl roof / trim / blades | B&O / JL Sound system | Probably more..
    Jun 03 2014
    2011 4Runner
    It will clear itself when the light is plugged back in
