Results 1 to 5 of 5
    Sep 24 2013
    orlando/ baltimore
    aftermarket Radio problem. can any radio tech guy helpppp.
    so i installed a pioneer radio in my car with bose. at first i had it hooked up with rca cables that come with the metro harness but the back speakers didn't work so i cut the rca cables and wired them straight to the head unit harness. when i first tested after hooking it up to the head unit harness it worked perfect, so i unplugged everything so i could make it all look nice and neat but once it was all hooked back up i don't get an sound from any of the speakers. all the wires at hooked together with the best wire connector you can find and i double checked after it stopped working. Could it be something with the amp, like a fuse for it.
    Jun 30 2008
    Erie, Pennsylvania
    What year is your car?
    Sedan or Avant?
    And some pictures of your wiring situation and a quick photo of the rear parcel shelf speakers (under-side) would be helpful.
    You can check fuse #37 - probably 20 Amp (for the Bose Amp or rear non-bose amp, depending what you have), but that also powers the radio, so it's doubtful that's the problem.
    Can you confirm:
    - You have RCA outputs of your new deck driving the FRONT stage. That was working, but now stopped.
    - You have the rear speaker-level output wires of your new deck driving the REAR stage. That was working, and now stopped as well.
    Sep 24 2013
    orlando/ baltimore
    nvm i found the problem. i bought rca loop thing so it make engine noise quite. it came with two brown cables to ground but every time i grounded them that is when i would lose my speakers. i just cut the brown wires from my ground and it works perfect every time now
    Jun 30 2008
    Erie, Pennsylvania
    Good work.
    Apr 09 2011
    Philippines
    I replaced the amp with a 4 channel sony. sounds way better now.
    1997 Audi A4 1.8T Quattro - Stroked to 2.0L, ABA crankshaft, 83mm Wiseco stroker pistons, Comp Turbo CT3-5556, AEM FIC6, 630cc injectors, VR6 Throttle Body, Schrick cams, Supertech valvetrain, IE intake manifold, Treadstone TR11 front mount intercooler, custom 3" stainless steel exhaust, Turbosmart 48mm Progate, Apexi AVCR EBC, Ringer Racing Stage 4 240mm full face clutch kit, Devil's Own Methanol Injection w/ 14 GPH Nozzle, 30 psi of boost.
