Results 1 to 6 of 6
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    Exclamation Possible A/C issues??
    So a few weeks ago, i did a couple hard pulls against a last gen BMW M6, a 500hp V10 monster, and somehow beat him every single time with my non tuned S4. I believe he didnt know how to drive the damn thing, shifting too fast with its SMG. Anyways, after all these back to back runs, i got on the free way and turned on the A/C only for it to not blow any cold air at all. The fan still worked but no cooling, so i assume the compressor was not turning on. Drove 5-7 miles down to my work and the as i started to park, the cooling came back on. I even did a trip to Cali the week after and the AC worked just fine all the way and back. I've done hard pulls before and the AC works then as well granted it was never back to back pulls like i did with the M6.
    Is this normal? Did engine management system just not turn on the compressor to avoid loading/ heating the engine further?
    Thanks
    May 26 2013
    Northwest PA
    Speculating here, but I know some A/C compressors will mechanically disconnect the compressor from the drive belt at high RPM's to keep from harming the compressor. It's possible that the compressor began operating normally once you returned to normal driving, not sure why that took 5-7 miles though, I would expect it to be a little quicker. My $.02
    2012 S4 GIAC Stage II | AWE Touring | Prestige | Monsoon Gray | Black Leather | Carbon Atlas Inlays | Advance Key | 6MT | B&O | Sports Diff | MMI+Nav |
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    I can confirm The AC clutch is disengaged at WOT. But soon after, it should resume normal operation. Not sure why yours took so long. Keep an eye on it.
    Feb 02 2016
    Peoria, Arizona
    well to be more accurate, once i noticed the cool air didnt come out, i turned off the ac unit altogether. I turned it back on once i got off the freeway and near to my work and ac worked and still works to this day with no problem. I occasionally do hard pulls from red lights ... just for kicks and ac still works no problem. hmm idk and i dont want to try to recreate it either.
    but regardless, the ac did not kick back on after a few minutes of hard driving.
    Senior Member Three Rings phxS4's Avatar
    Oct 09 2013
    Phx/AZ
    That problem hasn't happened to me before. I'm also tuned but don't think that matters. One thing is for sure... You don't want to be without AC this weekend...
    2013 S4 | Brilliant Black | DSG | Sport Diff | Fine Nappa | Carbon Atlas | B&O | Advanced Key | SC Badges | Roc Euro | AK | AWE catback | H&R OE l v810| GIAC Stage 2+
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by phxS4 View Post
    haha yes.. and thank fully the A/C has been working just fine. *knock on wood*
