Results 1 to 13 of 13
    Established Member Two Rings slytwyn's Avatar
    May 17 2016
    Michigan
    Audi A4 B7 S Line LED in headlights
    I want to put LED strips in my headlights but I'm not exactly sure how to do it. I know I have to bake the headlights and remove the lens, but I don't know any wiring from there. Can anyone give me a breakdown or anything of the headlights and the daytime running lights wires and the turn signal wires? It would be much appreciated.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    This all really depends on what LEDs you use and such. If you do not know how to wire leds and resistors I would start there before opening your headlights. If you buy the strips of LEDs on eBay you're going to be disappointed.
    Research this prior to starting and its not bad. I had halogens so I bought a shit set of lights off eBay and rewired new LEDS and resistors to make them actually look decent.
    Just a heads up this thread will most likely be trolled due to the amount of posts like this on the site. Search around and you'll find a few good posts for it. One where a guy rewired the eagle eye headlights and they look decent.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Nov 15 2011
    Montreal | I sell in USD
    *****I sell in USD*****
    Jan 13 2016
    If you're tapping LEDs into wiring you won't need resistors. Wiring is pretty self explanatory as long as you know which bulbs in your housing are what and for cracking the headlights open I would just use a blow dryer and heat mostly the signal corner. I've done three sets of B7 headlights and never had to bake them, just hit the signal corner with the most heat and pull. Are you wanting to run the LEDs as DRLs or as switchbacks? (White with signal off and flashing amber with signal on)
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by texpoops View Post
    You do in fact need resistors if your leds do not match the power put in. Or you can fry them, doesn't make much difference to me.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Quote Originally Posted by Axis View Post
    Hahahahha....This x 2.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Aug 17 2013
    Rossford, Oh
    Told you lol.
    Nov 15 2011
    Quote Originally Posted by yeoj112689 View Post
    Told you lol.
    I'm just very conservateur, imo you either go oem or try to source a set of lhd osram headlights.
    Oct 24 2015
    Perth, WA
    Overly priced. I don't see anything wrong with some of the options aftermarket.
    My respray thread
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    I opened my headlights last weekend to Joey Mod them. Didn't bake them at all, just pulled them apart and put them back together, but I'm really strong so you made need to bake them.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by adam044 View Post
    Someone is going to crack their lights because of this post lol.
    Dec 19 2012
    Europe
    I'm really strong
    cool story bro
    Oct 31 2014
    NH
    Quote Originally Posted by BenMTL View Post
    cool story bro
    Thanks man! I didn't think it was that cool but, I guess so!
