Results 1 to 19 of 19
    Established Member Two Rings SweetinsanityTT's Avatar
    Oct 09 2010
    2007 Audi RS4, 2010 Volkswagen Jetta TDI (Sold), 2001 Audi TT Quattro Big Turbo (Sold/RIP)
    Other Side of the Pacific
    Stasis Suspension? Is the company dead???
    I looked and couldn't find a clear answer any where and to complicate matters their site is still up and functioning. Tried calling and email but got no response.
    Only reason i ask is i had a rear shock mount crack (No clue how it happened. Lower shock mount - threaded piece attached to shock) and im trying to see if I can find a replacement over redoing the entire suspension system.
    Any help or insight would be greatly appreciated. Thanks.
    Oct 11 2007
    Suburbia
    Yes, they are done. I'm sure parts could still be sourced though, try contacting PSI or similar suspension people.
    12' R8 Daytona/CF V10 6MT
    ~VF750 supercharged~Avior Ti non-res~GT coilovers~Girodiscs~Wingbacks~CF S-wheel~Maxton Aero bits~
    07' RS4 Daytona/Panda
    ~Jackal tune~Zinram 70mm DPs~JHM res catback~Custom CAI~Bilstein PSS9s~Girodiscs~JHM shifter~
    Oct 09 2010
    Thanks. I will do that.
    Veteran Member Three Rings WerkzRS's Avatar
    Apr 13 2005
    B7 RS4, B8 SQ5, Jeep JK
    LA/IE
    Stasis/Ohlins the parts can be found directly through Ohlins. Statis just put their name on the suspension due to custom valving.
    2007 RS4 Daytona Gray, 80K (11/01/17) Ohlins/Statsis MS coilovers, ZIZA LED Interior, Milltek DP. w/ Non res valved catback, RNSE 2010-11 upgrade w/ AMI Integration and airtunes adapter (stream music), Euro TTRS steering wheel, Valentine Hardwired, WORK Emotion Cr Kiwami 19x10.5 ET 22 265/30-19..........scared money, don't make money!
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Heard some people have had bad luck with PSI lately. Another guy went through Feal suspension in California, he said they were reasonably priced and the turn around time was much quicker than PSI.
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by Peter1.8t View Post
    PSI isn't fast during parts of the hear, but they tell you that. They have always done excellent work for me for extremely reasonable prices. I would recommend them to anyone.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Dec 03 2009
    PNW, Washington
    Quote Originally Posted by BenSti View Post
    I hear you. I always used to hear great things about them. It's just lately I've heard some not so good things. Even Jason had a few words to share about them on some recent business with them. I was just letting everyone else know there's some other options out there as well to shop around.
    Oct 09 2010
    Thanks for all the advice. I am working with PSI right now but its quickly becoming cost prohibitive and is starting to involve custom machining. Based off of the conversations so far its going to cost around between $325 - $420 for two replacement end eyelets. Turns out I have a very early version of the Stasis SL suspension on the car. The rear eyelets had manufacturing oversight which enabled corrosion to build up between the eyelet and the bushing leading to the failure I experienced (The rear eyelet cracking in half). They subsequently changed the setup in the later designs.
    I will reach out to Feal as well just to see if maybe they have a replacement part in stock or can recommend a more cost effective solution.
    The question I have for you guys would there be an issue with retaining the front coil overs and replacing the rear Stasis SL Shocks to another aftermarket options such as Bilstien (Can replace both for 240 bucks)? My best guess is the set up has around 45 - 50K miles on the vehicle as it sets. With the difficulty of finding replacements parts I would assume a refresh of these is out of the question.
    Let me know what you guys think or if there is another recommended suspension setup out there.
    Link to Setup thats on the car:
    http://www.stasisengineering.com/pro...challenge-2007
    Established Member Two Rings B5man17's Avatar
    Jun 24 2013
    MN
    I have a set for sale with 0 miles on them since the rebuild by feal suspension, $1300 let me know if you are interested.
    Catless DPs, Magnaflow CB, 034 rear sway and end links, tint 20%, enkei ts9 pss (summer), BBS SR with R2 snows(winter), JHM R1 clutch and flywheel, JHM shot shifter, JHM shift knob, JHM tune, ohlins coilovers, stub trans and rear diff mounts.
    Feb 23 2010
    Nebraska
    Yes, Stasis is dead.
    I used FEAL to rebuild my ohlins. Highly recommended. Did a great job.
    ~ Matt J
    IG: @rsrtsvt
    '08 RS4 -- Suzuka
    991.2 GT3 -- Chalk (SOLD)
    '15 R8 V10 Plus (SOLD)
    '07 PB Audi RS4 (SOLD)
    Veteran Member Three Rings Bpitz15's Avatar
    May 07 2008
    Hartford County, CT
    Quote Originally Posted by ad2330 View Post
    Can confirm.
    Items for sale PM me for details:
    A6/Allroad 4.2 V8 top end
    Jul 21 2008
    Phoenix
    Quote Originally Posted by Bpitz15 View Post
    Can confirm.
    I can confirm as well. I just got mine back a few days ago. Good communication and it was done sooner than they is originally told me. Good stuff.
    Oct 09 2010
    Total cost came out to $250 so all in all not to bad considering the circumstances. PSI has been very helpful and informative the entire time so shout out to those guys for the help.
    Also when I get mine rebuilt I will reach out o Feal. Looks like they do a great job.
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    Quote Originally Posted by B5man17 View Post
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Oct 09 2010
    Quote Originally Posted by my_RS4 View Post
    My_RS4, get them. I love the way they feel on my car and thats a great deal.
    Jul 21 2008
    Phoenix
    Yeah seriously, that's a fantastic deal.
    Jun 18 2009
    Phoenix, AZ
    Also, oven cleaner works really well to make them look like new :) Ask me how I know.
    2017 Camaro SS 1LE
    Jan 23 2014
    Audi A5, VW '73
    Phuket, Thailand
    it's done. just order parts and re-valved my set from ohlins.
    Senior Member Three Rings guglielmo's Avatar
    Feb 02 2008
    Westchester, NY
    Nice, I found an new set of SLs to swap in when I rebuild my Motorsports.
    B7 RS4 mugello
    B7 S4 moro
    Q5 meteor
