Results 1 to 24 of 24
    Veteran Member Three Rings BarEaterB8's Avatar
    Nov 13 2011
    2009 B8 A4 - 1985 Porsche 911 - 2016 BMW M2
    Getting a Hesitation
    So recently, under moderate to hard acceleration I have been getting a hesitation/sputtering. It seems to happen throughout the powerband. The car starts just fine, and drives fine 90% of the time. There is no CEL's popping up but it seems to be getting worse. I am thinking maybe it's the plugs or coils but I am really not sure. I figure it has to be something with the ignition system. The car is fine at idle and under normal acceleration, it only happens when I really push down on the gas. Before I just start changing parts I thought I would ask here. I did a quick search and it seems like it is probably the plugs. I am Stage 2 Unitronic with the factory plugs. Thanks in advance.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Freshen up the plugs and coils just to start there, as they could probably use it anyways, and I bet they need to be gapped down. Another likely suspect would be the n75 boost solenoid valve if the problem continues.
    2016 S3
    Instagram- @Thisisastickup
    Nov 13 2011
    Cool, thanks. I just ordered some plugs and we will see. I went with the NGK BKR7EIX.
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by BarEaterB8 View Post
    Is your car running a tune?
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Nov 13 2011
    Quote Originally Posted by blbroo View Post
    Yeah Unitronic Stage 2
    May 22 2013
    Southern ME
    Quote Originally Posted by b6Hate4 View Post
    This. Make sure to gap the new ones before they go in (and check the old ones when they come out). I just replaced mine and they were up at .035 and beyond. Everything runs much much smoother at .028 on a stg 2 tune.
    Oct 26 2012
    St. Louis, MO
    We need to add a DIY to the stickie string on preparing for a tune. I'll write it up over the next couple of days with help from some other guys.
    1. make sure your plugs are new and at least NGK 7 heat range and gapped at 0.028 or lower, this is even more important if you don't have an upgraded intercooler
    2. if not on the new version coil packs, swap them in
    3. make a run through all boost and vacuum hoses to tighten connections to avoid small boost leaks
    4. maybe should be #1. How is your carbon build up? if bad, get it cleaned
    5. To be continued
    There should really be a checklist from each tuner for the car owner to go through before they have the file loaded, instead, many shops just allow you to pull your car in, pay them and have a tune loaded that demands much more consistency and precision from the car.
    Nov 13 2011
    5. To be continued
    Thanks for the feedback:
    I did the plugs and gaped them as you suggested. I haven't had a chance to drive the car yet but I will later today. If the hesitation is still there I will try doing the coils as well. Thanks for the help.
    Nov 13 2011
    So just by changing the plugs to a colder range and gaping them as advised, the situation seemed to clear itself up.
    Oct 26 2012
    St. Louis, MO
    Nice!
    Both the higher gap and the heat range lead to the plugs getting too hot, so hot that they explode the gas/air mixture before the plug even fires, causing the predet. It's really dangerous for your car to run like that because the explosion can happen while the piston is still on it's way up, possibly snapping a rod and shooting it through the side of your engine block. Less dramatic, it can blow the tip off of the plug, which can score your cylinder walls or F up your turbo blades.
    Glad you got it fixed.
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    So plug recommendation for a stock engine would be the NGK BKR7EIX?.I don't have any sort of issues just want whats best as a preventative measure.
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    no stock is NGK PFR7S8EG
    Senior Member Two Rings sidkneeeeee's Avatar
    Jul 09 2013
    Fairfield, CA
    5. To be continued
    what is the benefits of carbon cleaning?
    2010 A4 2.0T P+ 6 Speed CPO / ECS Interior + License led lights / RS4 Grill + Honeycomb Fog cover / Sline Rims 255-35-19 Et43 / ECS Spacer 10mmF:12.5mmB / ECS Inlet hose + Dry Filter / B12 KIT (Bilsteins Shock / Eibach Springs) / 10mm+12mm spacers / Wrapped interior + Window trim + Jcodes / ECS Shortshifter / LED 3200K Yellow Fog / Coilpack, NGK plugs / GFB+ DV / Revo Stage2 / Eurocode HFC / Hotchkis F:R Sway Bars / ECS Transmission Mount Inserts/ Future Mods: Podi Boost Gauge ; 3.0 TDI IC
    Nov 13 2011
    Nice!
    Thanks for the great advice!
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by sidkneeeeee View Post
    Come on man...use the damn search button.
    2016 S3
    Sep 02 2008
    Quote Originally Posted by kt883 View Post
    Yes I know but would a colder plug like the NGK BKR7EIX be smoother?.I'm getting very light roughness during idle.
    Established Member Two Rings dbv2's Avatar
    Mar 06 2016
    To
    NGK PFR7S8EG recommended gap size?
    I also get a hesitation, I just did plugs and R8 coils, no tune. I'm not sure if its a boost leak or its the ignition system. I did not check the gap size prior to install.
    Oct 26 2012
    St. Louis, MO
    Recommended is 0.032 stock and 0.026 or 0.028 tuned
    Nov 13 2011
    I am amazed at how much smoother the car is just by changing the plugs. Acceleration is much quicker and I am at 70 like it is nobody's business. I am passing people who I think are going slow and I look down and I am at 90. I was always a bit skeptical after I got my tune that I did not notice that much of a difference but now, two years later I notice it. I can't believe I didn't do this sooner.
    Oct 26 2012
    St. Louis, MO
    Awesome, it's like a $30 tune upgrade.
    Aug 17 2015
    California
    When was the last time you changed your plugs?
    What do you guys reccomend to change at? I think the maintenance schedule calls for every 55000km (34000mi).
    I'm on the stock tune and it has been at least 35000km (22000mi) since my plugs have changed. I'm not even sure cause I bought the car used (CPO). Could have been a touch longer. I think it's time I order some.
    May 22 2013
    Southern ME
    Quote Originally Posted by A4x View Post
    Just as a data point, I did mine for the 55k service and at 98k I got my first full load misfire. New gapped plugs and drives much better. I'll probably go every 40k from now on.
    Nov 13 2011
    For the $30-40, and 15 minutes it takes. It doesn't hurt to do it.
    Aug 17 2015
    California
    Quote Originally Posted by ducati View Post
    Same question, can we run the colder plug on the stock tune? (in my case, with HFC)?
