Results 1 to 35 of 35
    Mar 29 2014
    Hampshire, UK
    4.0TT Engine Oil Change - Frequency?
    Hi Guys,
    I have a question for you 4.0TT owners.....
    At what mileage/frequency do you change your engine oil?
    I've had my car (new) for 6 months now and it's covered almost 10,000 miles. It's on the variable service interval setting, and the MMI says it doesn't need an oil change for another 18 months or 6000 miles. As the car was new when l got it, it's never had an oil change - although lve topped up about 2litres in this time.
    Should l do an oil change at 10,000 miles, independent of the dealer/MMI recommendation? I'm not tracking the car, and it's not ECU tuned. Is there any benefit (other than my own feelings) to doing an early oil change?
    Cheers,
    John.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Active Member Two Rings sonjh81's Avatar
    Aug 31 2015
    Seoul, Korea
    6 months or 5000 km
    2013 Audi S6 4.0TFSI Quattro
    Havanna Black Metallic, Fully loaded
    APR Stage 2 ECU, APR Downpipes
    Dec 18 2014
    DMV
    You've had it since new and never done an oil change? and you've driven it 10k miles?
    First oil change (which should be free) is at 5k miles, and then every 10k miles after that - per audicare.
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    Quote Originally Posted by Serpent View Post
    +1
    Sent from my keyfob
    '23 Tesla Model X | '17 Ducati Supersport S
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    My car's tuned so I change it every 5,000 miles to be on the safe side.
    Mar 29 2014
    Hampshire, UK
    That is Audi USA recomendation. Its not what Audi Europe recommends.
    Does the US market have variable rate service intervals?
    Established Member Two Rings TD_05's Avatar
    Dec 19 2013
    2016 Audi S6 2005 BMW M3 1994 Nissan King Cab
    Midwest
    Blatant thread jack sorry OP. Do you guys recommend the first oil change to be performed sooner then the 5k AudiCare free one to maximize engine "health" etc? I plan to keep the car a long time, and am aware I'd have to pay out of pocket for the first one. If so at what milage? 1500 or so?
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    Quote Originally Posted by HeelBuff View Post
    +1
    I do the same.
    2015 Porsche 911 Turbo S
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    +1 I do the same. 5k
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Senior Member Two Rings DB22's Avatar
    Feb 12 2014
    So Cal
    Quote Originally Posted by TD_05 View Post
    First oil change is fine at 5k. You don't have to do one sooner and then 5k. Every 10k after that.
    2014 A6 Prestige. VCDS, Chipwerke.
    Apr 21 2014
    Hayden Lake, Idaho
    Over here in the Vol 4.0T Baller Club we do it every time we drive the car.
    In all seriousness I change mine every 5K due to tune + mods.
    2014 Audi RS7 - Daytona Gray Pearl / Carbon Optics / Carbon Mirror Housings / Carbon Inlays / B&O with 12" Digital Designs Custom Sub Enclosure and Digital Designs Amp / Full Xpel Wrap / APR Stage 2 Tune / Milltek Non-Res Exhaust / Milltek Catless Downpipes / H&R Module / Eurocode Sways & Endlinks / Gloss Bronze HRE P104 / Smoked Tail Lenses / Body Color Side Lenses / Empty Wallet
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    If you are going to keep the car forever, I think it's a good idea. Otherwise I doubt you will ever notice the difference in engine life that it makes from circulating the additional metal and particulates for the extra 3500 miles.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    The whole oil change every 5000 mile thing is overkill. Tuned or not. Unless you are really driving your car hard all the time, and with frequent short trips, I wouldn't worry about it. What is more important is that you use a high grade synthetic oil. The recommendation for frequent changes comes from the time when there were no synthetic oils. Todays formulations are much much improved. Porsche, for instance, also recommends changes every 10,000 miles. I had my initial free oil change done at 5000 miles. Then at 15,000, then at about 22,000 and again at 29,000 (only because my brake fluid needed changing and I didn't feeling like making another trip for the oil a few months later). I will get the next oil change at 35,000 with the major service on my S6.
    Don't sweat it. 10,000 mile intervals are fine, or maybe 7500 if you are really concerned. Topping up in between as needed also adds fresh oil although I haven't needed a spot of extra oil in 30,000 miles of ownership. This, however, can be influenced by how you break in your car.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    I think that the 5k first oil change is to get you back into their service as soon as possible to that you don't end up going to a different dealer.
    Mar 26 2010
    US
    The USA oil change frequency in the maintenance schedule was changed by AOA for the 2017 models (10k first, then every 20k)
    My 2016 had 5k for first oil change in the manual & MMI.
    From 2017 schedule: "Minor Maintenance Service
    First at 10,000 miles or 1 year after delivery, whichever occurs first. Thereafter, every 20,000 miles or two
    years, whichever occurs first......Engine oil / Oil filter - Change oil and replace filter ....
    1. First Minor Maintenance service at 10,000 miles or 1 year after delivery, whichever occurs first. Minor maintenance services thereafter occur at intervals of 20,000 miles or 2 years after the
    last minor maintenance service, whichever occurs first."
    2016 Audi Maintenance Schedule - Audi USA
    MY 2017 Audi USA Scheduled Maintenance
    2019 RS5 Sportback
    Veteran Member Three Rings Frenetic's Avatar
    Dec 13 2015
    '17 Audi S7
    CA
    I asked this question as well and for a 2017 it actually lists 10,000 miles for the first oil change. It says this is the warranty/maintenance guide and in my car.
    The 2016 or earlier user's manual may be different?
    I personally think that's too long, especially for the first oil change. But I'm not sure what in going to do: do it at 5k or wait until 10k per the book.
    2020 BMW X5 M50i | 2017 AUDI S7 (gone)
    Mar 29 2014
    Hampshire, UK
    If your going to do it for peace of mind, ld consider using an Indy to do just an oil change, then leave the 10k to the dealer.
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    this is the standard. Any more frequent provides very little additional protection and costs u money...8 quarts and a filter if u do it yourself. I recently got an Audi oil change promotion for 69.95. So the regular price must be higher. The frequency seems to be a personal preference. Going more than 10k miles is pushing it. Just my opinion...
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
    Jan 09 2013
    UK
    I change mine every time it hits minimum which is usually 8-9k miles so 1/2 of variable service recommendation. Get an Indy to do it, usually costs about just over a ton all in.
    Apr 28 2017
    CO Mountains
    Does audicare cover synthetic oil changes, or do they use standard oil?
    2016 Sepang S6 - APR Stage I
    Mar 26 2010
    US
    Quote Originally Posted by Buffarino View Post
    Audicare uses synthetic oil.
    For the 2017 models, they have doubled the mileage between required oil changes in the maintenance schedule.
    2019 RS5 Sportback
    Jun 30 2016
    NNJ
    +1, though I'd do it every 5k even if it was stock. Cheap insurance.
    May 14 2008
    2015 S8; 2020 Q3 Prestige; 2012 Golf R (w/ the six speed...)
    SF Bay Area CA
    Quote Originally Posted by wwhan View Post
    I don't think this is correct. What they did was moved the first oil change to 10K miles instead of 5K. It has been 10K intervals for many years now in general. And I think it would be nuts to run a new car 10K miles before first oil change. I try to do a first one at 15-2500 miles, regardless of who pays for it or if it is included in AudiCare or not.
    Mar 26 2010
    US
    Quote Originally Posted by MP4.2+6.0 View Post
    Did you read the 2017 maintenance schedule, link posted above?
    Oil change only on minor maintenance, every 20k.
    2019 RS5 Sportback
    Established Member Two Rings _SILENCER's Avatar
    Jan 14 2016
    Southern California
    I swap oil every 5000 miles on any car I've owned since 2005
    Nov 18 2014
    Jersey
    i do an oil change ever 5k on the cars i own.
    if it's leased i give no fucks and go by whatever schedule the dealer says.
    2018 Jeep GC Trackhawk
    2022 Audi SQ7
    2017 R8 TT. 1370whp.
    2007 Porsche 911 Turbo...Bolt On's
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    I guess the better question is what oil are you guys using then?
    2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
    2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by ZipMeUpJ View Post
    Fully synthetic 5W-30 for me, to VW 504/507 specification
    Feb 15 2011
    Northern VA
    Whatever you do, don't listen to the recommendations on the manufacturer who engineered the engine, and are held to a warranty.. they don't have a clue.
    The oil companies appreciate your extra $$, though.. just in case they weren't screwing you enough at the pump
    Mar 28 2014
    The Big Apple
    For a more definitive answer, I suggest getting a sample of your used oil analyzed
    https://www.blackstone-labs.com/
    Oct 02 2005
    The Moon
    Quote Originally Posted by Yeoman View Post
    Same company that says transmission fluid is lifetime while the actual producer of the transmission in the vehicle states change every 60k miles? Hmmm
    Feb 15 2011
    Northern VA
    My point is it's not in the best interest of Audi from a warranty, reliability, or reputation standpoint to publish maintenance intervals which are detrimental to the engine. Synthetic oil production continues to make advances to extend usable life.. it's not the same formulation from 2006.. Same with motor production, which has evolved to exacting tolerances making the days of metal shavings and other production contaminants a thing of the past.
    Nov 12 2012
    hologram R8
    boston
    random: Yeoman as in "$ yo webapp" Yeoman, or just general definition yeoman ?
    Feb 15 2011
    Northern VA
    yup
    Nov 13 2016
    Houston, TX
    I change mine every 5K miles. Although oil quality and durability has come a long way, filter quality and durability has not.
    Sent from my SM-G955U using Tapatalk
