Results 1 to 17 of 17
    Dec 21 2013
    Engine vibration at red light
    So I'm experiencing light vibration when idle at red light. Not violently but something you have to pay close attention to notice it. Just wondering if this is normal with the 3.0 engine? My car is bone stock.
    Current: 2021 R8, 2019 A6, 2017 Ghibli SQ4
    Past: 2009 C300, 2011 C63, 2013 535i, 2014 S4, 2016 M4, 2016 Macan, 2017 Macan Turbo, 2017 E350, 2017 750i, 2018 Panamera Turbo
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    My understanding is that it's normal.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Jan 09 2008
    Winnipeg
    I get the same thing. It's kinda intermittent though as some days are worse than others. I take it as a characteristic of an Audi. I've driven different models of S4, A4, Etc and they all vibrate at idle at some point.
    Established Member Two Rings darkstarghost's Avatar
    Feb 08 2014
    2014 Estoril blue s4
    my car does this at idle all the time. Figured it was normal since it happened since i bought it.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    It's normal, however I recently made a change to my plug gaps that eliminated this slightly lumpy idle quality just to experiment. My OEM plugs ranged from a .026-.030 gap when I removed them, I re-gapped them to .032 and it smoothed out the lumpy idle, like almost Toyota Camry smooth, but the engine response didn't seem as crisp to me, particularly up in the rev range. However, I installed new plugs and gapped them all at .028, idle quality seems slightly rougher than the .032, but not as rough as having a few gapped at .026 though. I used a .028 gap for performance reasons and at the recommendation based on other threads.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Completely normal. It's the "hot rod" in the engine coming out.
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    If you search for rough idle on the forum, you'll see a lot of threads about this. Common characteristic of the V6 engine, though there was one thread here where somebody pushed and pushed for a fix and something was done to address the idle (maybe the idle on his S4 was much worse than the norm). It's really noticeable if you give it enough gas to idle at 1,000RPM, it's really noticeable at that RPM.
    Audi has a TSB, 24AS, which updates the ECU to address the rough idle to some degree, I think it was only for the early B8s as it was applied on 2010s like mine and 2011s on others. Also, if the secondary air intake is has enough buildup, that can also contribute to the rough idle but at the same time, the odd misfire here and there at low engine RPM as I experienced. After the SAI was cleaned things were much smoother (but idle still not the smoothest) and no more misfires.
    Mike
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    I just noticed my car idling for the first time in my ownership. - it's weird.. i mean, on one hand it is so subtle and feels totally normal like any car would but it wasn't there for the first 20k . . . I just fear it could be the motor mounts going as i've heard a few folks have had that issue.. for now, my idle seems normal but i'm keeping a feel of it.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Normal. Through me for a concern though when very first test driving some low mileage ones during the shopping experience. Guess one of the very first cars I drove wasn't having any engine related issues but the sales guy didn't tell know much and I walked on that one. Wasn't until later that I read through threads and learned I wasn't nuts.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Apr 05 2016
    Portland, OR
    I only notice it if I have something on my passenger seat. For whatever reason that is where the most vibration seems to be.
    I always assumed it was normal.
    Dec 21 2013
    Quote Originally Posted by Tanner View Post
    Where is the SAI. I might give this a try, the vibration is not that rough but I just can't stand it...
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    It is normal. My car had zero vibration when it was brand new; now it has a very subtle vibration a year later with 11.5k miles.
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Quote Originally Posted by The Fat Kid View Post
    Can confirm intermittent vibration on a '16 with 3k miles. It actually feels like my late grandfathers old 67 chevelle ss to some degree. I like it.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Same here, noticed it since I bought it. Dealer said there was nothing wrong
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Same here ... I took mine in for it but then I took another S4 out for a drive and there it was. Like others said it is very intermittent.. Sometimes I can go a day or two and its super smooth... Then the "old muscle car rock" comes back..
    Apr 14 2016
    Atlanta, GA.
    Same here, I've got a 2011 with 50k miles on it and it's noticeable when chilling at a light and my hand is on top of the wheel..
    Established Member Two Rings fillyo's Avatar
    Jan 22 2015
    Chicago, IL
    I also have a 2011 with 51k miles, I noticed this a week or two after I bought it last year, took in twice, they said it was normal. I am used to it now, it comes and goes.
    Phil
    2011 S4 Prestige | Ice Silver | 6MT | SD w/ ADS | Silk Nappa | Nav | Carbon Atlas | Blind spot | B&O |
