Results 1 to 3 of 3
    Veteran Member Three Rings betyouaint's Avatar
    Mar 31 2010
    2016 Chevy Silverado Z71
    Wherever I lay my hat...
    Replacement Resonator
    I just swapped out my flex-pipe for a cheap Bosal replacement and noticed that my mid-box (resonator) is also blowing. The rear mufflers are okay and I would like a mid-box that will fit the OE mufflers. As the front flexpipe is a Bosal I was wondering if the Bosal resonator (like below) would fit the mufflers?
    https://www.rockauto.com/en/moreinfo...432022&jsn=555
    Or might I have better luck with the Walker (remembering the front flexpipe is Bosal)?
    https://www.rockauto.com/en/moreinfo...432022&jsn=556
    If I'd realized that I needed both parts I'd have probably invested in an OBX system but I can't justify that extra cost and effort now.
    2006 Audi A4 2.0T Quattro Tiptronic - Now over 240k but still ticking along...
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Instead of using inline resonators...You can also just use an X-pipe I believe...Not sure the differences but both should help with excessive noise and drone. Got a decent x pipe off ebay for $50 shipped.
    I'm getting a custom made 3" cat back done locally, only bringing my own HFC, flex pipe section, x pipe, and magnaflow mufflers...Hoping they can fab the rest for me.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    That appears to be a direct OE replacement. We don't have experience with that brand, but there should be no issue using them with your stock mufflers.
